Power Query Conditional Running Total with If Statement - Advanced Problem
- 4 years ago
Hi SpreadsheetPete,
This is probably not the neatiest solution, but you can try something like this:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amQMpQKVYHLm6KEDdCFjdHiBvjUG+CLG6JEDcFizth2GuGLI5kjjmyOJK9FmBxZwxxSyRxEyRzDA2QNSA5yBDo41gA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t, Index = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}, {"Index", type text}}), Aggregate = List.Accumulate(Table.ToRecords(#"Changed Type"), {}, (a,n)=> a & { Record.AddField(Record.AddField(n, "CubeFill", n[Volume] + (if List.IsEmpty(a) or List.Last(a)[CubeFill] + n[Volume] > n[Cube] or List.Last(a)[Filter] <> n[Filter] then 0 else List.Last(a)[CubeFill])), "PositionCount", if List.IsEmpty(a) or List.Last(a)[Filter] <> n[Filter] then 1 else if List.Last(a)[CubeFill] + n[Volume] > n[Cube] then List.Last(a)[PositionCount]+Number.RoundUp(n[Volume]/n[Cube], 0) else List.Last(a)[PositionCount])}), Output = Table.FromRecords(Aggregate) in OutputKind regards,
John
- 4 years ago
I corrected the code in fxCalc.
(A)=> let RunningTotal = Table.AddColumn( A, "Running Total", each if [Volume] < (Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) then @RunningTotal[Running Total]{[Index]-1} + [Volume] else List.Sum(List.FirstN(A[Volume],[Index]+1)) + ((Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0}))) ), CubeFill = Table.AddColumn( RunningTotal, "Cube Fill", each [Running Total]/[Cube] ), PositionCount = Table.AddColumn( CubeFill, "Position Count", each Number.RoundUp([Cube Fill],0) ), RemainingSpace = Table.AddColumn( PositionCount, "Remaining Space", each [Position Count] * [Cube] - [Running Total] ) in RemainingSpaceMain Query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amSrE6cDFTLGLmRKqzRBZzwmKHExa9TljscMYpZmKKRR3C3lgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Filter"}, {{"Group", each fxCalc(Table.AddIndexColumn(_,"Index",0,1))}}), Combine = Table.Combine(#"Grouped Rows"[Group]) in CombineRegards
KT
HI SpreadsheetPete ,
The challenge I can foresee now is the cyclic reference based on your excel formula between the Remaining Space and Running Total column. I will have an attempt with the recursive method later and let you know if any luck.
Regards
KT
Amazing Thank you
I did have some luck by adopting the below code and it works very closely yet it causes missed calculations after only some of the records. here is my latest code.
Also here is the updated Excel file demonstrating the output of the code and the error
the best code so far
Source = Excel.CurrentWorkbook(){[Name="SourceTable"]}[Content],
#"Added Index" = Table.AddIndexColumn(Source, "Index", 0, 1,
Int64.Type),
CorrectTypes = Table.TransformColumnTypes(#"Added Index",{{"Index",
Int64.Type}, {"Filter", type text}, {"Volume", type number}}),
each List.Sum(Table.SelectRows(CorrectTypes, (Q) => Q[Filter] =
[Filter] and Q[Index] <= [Index])[Volume]), type number),
Runing = Table.Group(CorrectTypes,"Filter",{"A", each let
A = Table.AddIndexColumn(_,"i")
in Table.AddColumn(A,"R", each
List.Accumulate(Table.SelectRows(A, (a)=> a[i]<=[i])[Volume],
[Running=0, Verifier = 1],
// Here the challenge begins
(s,l)=> [Running = if s[Running]+l >
(Number.RoundUp(s[Running]+[Volume]/[Cube])*[Cube]) then
((Number.RoundUp(s[Running]/[Cube])*[Cube])-s[Running])+s[Running]+
[Volume] else s[Running]+l , Verifier =Number.From(s[Running]+l
<=Number.RoundUp(s[Running]/[Cube])*[Cube] )] ))
ExpandedR = Table.ExpandRecordColumn(
Table.ExpandTableColumn(Runing, "A", {"Volume","Cube","i", "R"}),
"R", {"Running", "Verifier"})
and here is the output
Code Output and formulas with desired outcome
