power query average using multiple criteria and grouping
Thank you Gao. As I am so new to this, the above code is a lot for me to understand. I tried to copy it and add it to a custom column but that did not work.
Am I right in thinking that I can add a custom column into my PQ table and add in the middle part of that code which would look like this (named the custom column "New Hire Avg CR")?
if [New Hire] = "New Hire" and [#"Compa Ratio"] <> "" and Number.From([#"Compa Ratio"]) > 0 then
List.Average(Table.SelectRows[#"Job Code & Country"]=[#"Job Code & Country"] and [New Hire]="New Hire") [#"Compa Ratio"] else null
Then the last part of your code would be formatting this custom column to percentage?
I have tried it as I described above, and although the formula looked ok in the editor, the average for New Hire is not calculating and is showing as error (the Existing employees are showing a null value which is correct). Could you please advise further on this?
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("rZVBa8JAEIX/igR687Azk012zyXUttBbT+JBMJRAjWADtv++1iQ6rq9Uh57CJrzHm33fbubzrKocZdPs6d4dnq9t09WryXPTvq026/HDxVuScLd/VJ/NR7d/mS2mByc2OBH9OL3Uu8ms2dajkyinx275/jWuxwVxjnS5IQELmsUrp4d6u162xwynJXFE2sKQwgc0T2lwciXKFAYBX8zDah5ipI1Kq9vgYxveAx05pYPpGfAAncjg1HeT7CixJRMihOTfnAZq/W8te3QCC+TkldNZy15TS4haKq7RRnTsqDQM4GCIYHDq4UszRYNTgeDjAWNJ8JcT/kJIR0qHEggARNA1wGxwYocyiXI6K1nUNRByJM1vDxEETeP/3E+HKOPi9gARnRIuDUboYuRg2BJYcLymlj5DIhVnGAZhLgZcI7rORNOK+4U/fRFDAAS5GEgll2zu4hs=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Employee = _t, #"Job Code" = _t, Country = _t, #"Job Code & Country" = _t, #"Compa Ratio" = _t, #"New Hire" = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Employee", type text}, {"Job Code", type text}, {"Country", type text}, {"Job Code & Country", type text}, {"Compa Ratio", Percentage.Type}, {"New Hire", type text}}),
#"Added Custom" = Table.AddColumn(#"Changed Type", "New Hire Avg CR", (k)=> if k[New Hire]="New Hire" then List.Average(Table.SelectRows(#"Changed Type", each [New Hire]="New Hire" and [Compa Ratio]<>null and k[#"Job Code & Country"]=[#"Job Code & Country"])[Compa Ratio]) else null, Percentage.Type)
#"Added Custom"
How to use this code: Create a new Blank Query. Click on "Advanced Editor". Replace the code in the window with the code provided here. Click "Done".
- KullyR2 years agoRegular Visitor
Thank you Ibendlin. Gao and you both gave me this code and I just wanted to understand it in case I need to edit or create a similar calculated column again. Is this begining part of the code always the same or does it differ depending on the query/table that I am in? (I am proficient in Excel, but very new new to the data model and DAX)
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("rZVBa8JAEIX/igR687Azk012zyXUttBbT+JBMJRAjWADtv++1iQ6rq9Uh57CJrzHm33fbubzrKocZdPs6d4dnq9t09WryXPTvq026/HDxVuScLd/VJ/NR7d/mS2mByc2OBH9OL3Uu8ms2dajkyinx275/jWuxwVxjnS5IQELmsUrp4d6u162xwynJXFE2sKQwgc0T2lwciXKFAYBX8zDah5ipI1Kq9vgYxveAx05pYPpGfAAncjg1HeT7CixJRMihOTfnAZq/W8te3QCC+TkldNZy15TS4haKq7RRnTsqDQM4GCIYHDq4UszRYNTgeDjAWNJ8JcT/kJIR0qHEggARNA1wGxwYocyiXI6K1nUNRByJM1vDxEETeP/3E+HKOPi9gARnRIuDUboYuRg2BJYcLymlj5DIhVnGAZhLgZcI7rORNOK+4U/fRFDAAS5GEgll2zu4hs=", BinaryEncoding.Base64)
This is why I was looking to try and add a formula as a custom column so I can at least try to understand it when I have to edit it
- lbendlin2 years ago
That code represents a compressed version of the sample data. Throw it away when you swap in your actual data source.
