power query average using multiple criteria and grouping
Thank you. I have attached a link to the file showing some sample data. The end result is in an excel formula in column G which shows the average 'Compa Ratio' for each 'Job Code & Country' where the employee is a 'New Hire'.
Column D has the grouping I want to calculate the average by
The yellow highlighted fields are all the columns that are included within my conditions
Hi KullyR ,
Please refer to the following steps:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("rZVBa8JAEIX/igR687Azk012zyXUttBbT+JBMJRAjWADtv++1iQ6rq9Uh57CJrzHm33fbubzrKocZdPs6d4dnq9t09WryXPTvq026/HDxVuScLd/VJ/NR7d/mS2mByc2OBH9OL3Uu8ms2dajkyinx275/jWuxwVxjnS5IQELmsUrp4d6u162xwynJXFE2sKQwgc0T2lwciXKFAYBX8zDah5ipI1Kq9vgYxveAx05pYPpGfAAncjg1HeT7CixJRMihOTfnAZq/W8te3QCC+TkldNZy15TS4haKq7RRnTsqDQM4GCIYHDq4UszRYNTgeDjAWNJ8JcT/kJIR0qHEggARNA1wGxwYocyiXI6K1nUNRByJM1vDxEETeP/3E+HKOPi9gARnRIuDUboYuRg2BJYcLymlj5DIhVnGAZhLgZcI7rORNOK+4U/fRFDAAS5GEgll2zu4hs=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Employee = _t, #"Job Code" = _t, Country = _t, #"Job Code & Country" = _t, #"Compa Ratio" = _t, #"New Hire" = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Employee", type text}, {"Job Code", type text}, {"Country", type text}, {"Job Code & Country", type text}, {"Compa Ratio", Percentage.Type}, {"New Hire", type text}}),
#"Added Custom" = Table.AddColumn(#"Changed Type", "New Hire Avg CR", each if [New Hire] = "New Hire" and [Compa Ratio] <> "" and Number.From([Compa Ratio]) > 0 then List.Average(Table.SelectRows(#"Changed Type", (x)=> x[#"Job Code & Country"]=[#"Job Code & Country"] and x[New Hire]="New Hire")[Compa Ratio]) else null),
#"Changed Type1" = Table.TransformColumnTypes(#"Added Custom",{{"New Hire Avg CR", Percentage.Type}})
#"Changed Type1"
Gao
Community Support Team
If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly.
If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data in the Power BI Forum -- China Power BI User Group
