nexami's avatar
nexami
7 years ago
Power Query / Power Pivot - stock calculation
I have a table in Power query, which besides other fields has the following key fields:
CMT | Year | Week | Customer | Transaction | Value
AB587 | 2019 | 12 | Tom | Purchase | 200
AB587 | 2019 | 12 | Tom | Sale | 15
AB587 | 2019 | 13 | Tom | Purchase | 60
AB587 | 2019 | 13 | Tom | Sale | 100
AB587 |2019 | 12 | Tom | Stock | 1600
AB587 | 2019 | 14 | Tom | Purchase | 50
AB587 | 2019 | 14 | Tom | Sale | 450
This is a table with about 300,000 rows with all the CMT and a couple of year's worth of transactions for all customers.
This is what it looks like right now:
CMT and Transaction as rows, and Weeks as columns, with Value as values, and customer as report filter.
the pivot table obviously shows what's in the raw data. What I want to do is to have the pivot table calculate the Stock for Weeks 13, 14 and so on. In the above example, I would expect the Stock in Week 13 to have 1600-100+60=1560, and Week 14 Stock to have 1560-450+50=1160, and so on.
Basically the pivot table should be projecting the stock in hand. I also want the pivot table to be able to do that when the CMT is removed from the rows and replaced by Customer or any other such combination. One more thing is that if the user brings in "months" instead of Weeks, the Stock should show the value of the last week of each month (the raw data has a month next to week in each row).
  • ImkeF's avatar
    ImkeF
    7 years ago
    If you're worried about performance, you can use this trick to substantially improve speed for a case like this: https://www.thebiccountant.com/2017/05/29/performance-tip-partition-tables-crossjoins-possible-powerquery-powerbi/
    Your code would look like so:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcnQytTBX0lEyMjC0BFKGRkAiJD8XSAaUFiVnJBangiUNlGJ18CkOTswBKTQ0xarOGJuhZtjNNMYwk7DlJfnJ2SAhMxxKTbDZb0pILdR+EySFFkSEFCHV8KDCrhBHWBFSjAgsgvYjhRZ2tTiCi5BiRHgBVcYCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [CMT = _t, Year = _t, Week = _t, Customer = _t, Transaction = _t, Value = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"CMT", type text}, {"Year", Int64.Type}, {"Week", Int64.Type}, {"Customer", type text}, {"Transaction", type text}, {"Value", Int64.Type}}),
        #"Pivoted Column" = Table.Pivot(#"Changed Type", List.Distinct(#"Changed Type"[Transaction]), "Transaction", "Value"),
        #"Added Custom1" = Table.AddColumn(#"Pivoted Column", "YearWeek", each [Year] * 100 + [Week], Int64.Type),
        #"Grouped Rows" = Table.Group(#"Added Custom1", {"CMT"}, {{"All", (Partition) => Table.AddColumn(Partition, "Custom", each List.Sum(
                Table.AddColumn(
                    Table.SelectRows(
                        Partition, let  _earWeek = [YearWeek] in each [YearWeek] <= _earWeek
                    "var", each [Sale]- [Purchase]
                )[var]
        #"Expanded All" = Table.ExpandTableColumn(#"Grouped Rows", "All", {"Year", "Week", "Customer", "Purchase", "Sale", "Stock", "YearWeek", "Custom"}, {"Year", "Week", "Customer", "Purchase", "Sale", "Stock", "YearWeek", "Custom"}),
        #"Replaced Value" = Table.ReplaceValue(#"Expanded All", each [Stock], each [Stock] + [Custom],Replacer.ReplaceValue,{"Stock"}),
        #"Filled Down" = Table.FillDown(#"Replaced Value",{"Stock"}),
        #"Changed Type1" = Table.TransformColumnTypes(#"Filled Down",{{"Stock", Int64.Type}}),
        #"Replaced Value1" = Table.ReplaceValue(#"Changed Type1",each [Stock], each [Stock] - [Custom],Replacer.ReplaceValue,{"Stock"}),
        #"Changed Type2" = Table.TransformColumnTypes(#"Replaced Value1",{{"Stock", Int64.Type}}),
        #"Removed Other Columns" = Table.SelectColumns(#"Changed Type2",{"CMT", "Year", "Week", "Customer", "Purchase", "Sale", "Stock"})
    You'll find some more performance tricks here: https://www.thebiccountant.com/speedperformance-aspects/
  • v-piga-msft's avatar
    v-piga-msft
    Icon for Resident Rockstar rankResident Rockstar
    Hi nexami ,
    I have a little confused about your logic firstly. If it is convenient, could you share your desired output?
    In addition, I have confused about your current output.  Do you have the output like below?
    If not, could you share a screenshot  about your output.
    Best  Regards,
    Cherry
    • nexami's avatar
      nexami
      hello v-piga-msft and thanks for your reply, please find attached output required
      Stock = Operning Stock + Purchase - Sale.
  • Mariusz's avatar
    Mariusz
    Hi nexami
    How often the stock is updated, is it once for every product?
    Mariusz
    Please feel free to connect with me.
    Mariusz Repczynski
    • nexami's avatar
      nexami
      hello Mariusz glad to hear from you, well the stock updates regularly having the following formulation:
      Stock = Opening Stock + Purchase - Sale
      Please check attached output example
      • Mariusz's avatar
        Mariusz
        nexami
        Is opening stock only one of value for every sku?
        Mariusz
        Mariusz Repczynski
