ogend's avatar
ogend
4 years ago
power query- generate a list for each record using "offset down" logic
Hi Power Query Gurus,    Is it possible to generate a list of records with the following pattern? I have 2 columns: "Text" and "Number".  "Number" provides a count of records I need in the list, a...
  • ronrsnfld's avatar
    4 years ago
    First add an Index column (with a starting index of 0).
    Then add a custom column with the formula:
    = if [number]=0 then null
        else List.Range(#"Added Index"[text],[Index]+1,[number])
    Finally, remove that Index column
    The M Code to reproduce this, which you can paste into a blank query:
    //the data
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("VY5LCoAwDESvIlm7EPU2xUWUoMX0Q2wt3t6iWHX5ZjKTUQrQeyaooYGhVuAJpXqJo8nQXWDQzi5Te1va0j+aMJAYYmeLtAXBNJLIUXJzxB3LwciRHr+/FCf5zVvKZD59q076O3VaCqEXPblw83AC", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [text = _t, number = _t]),
    //set the data types
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"text", type text}, {"number", Int64.Type}}),
        #"Added Index" = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1, Int64.Type),
    //add custom column
        #"Added Custom" = Table.AddColumn(#"Added Index", "List",
            each if [number]=0 then null
                    else List.Range(#"Added Index"[text],[Index]+1,[number])),
        #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Index"})
        #"Removed Columns"
