cottrera's avatar
cottrera
Icon for Post Prodigy rankPost Prodigy
4 years ago
Power Query - Aggregate and transpose help
Hi    Can you please tell me how I can use power query to transform this table Job_Number VoidPK Cost Type Base Amount IWDEC570 C570Voids LABOUR 33 IWDEC634 C634Voids LABOUR 110 ...
  • BA_Pete's avatar
    4 years ago
    Hi cottrera ,
    I've included the code to do what you want below, but the first question is: why do you want to do this? The original format of your data is the optimum and most efficient structure for reporting. Using expensive resources to move the structure further away from optimum is not generally considered best practice.
    The answer to your actual question:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("vZXBbtswDIbfJedCEClRoo5pFwTFMmxovO1Q9NbLTj30/YGRcmDJk6J4xbDTbxsfSIr8RT8/7x5/fjo8ULS7u53Kj7dfr+/yfNrff/3+JA/O7V7uLlhwXjGRBgOwFechcx5ucEyZY2o47wvGlMOJfBSL8YIdTgGUUmkoDM5QFc9yjmd5fIoRxyUxsWIqtxJTyAcRGQTcyn2+BwryRaVN7JyJ9AESSZ2gMia1ShdylW4J+mU/HZ4e96dz7qSxWMFpNmJqjRirkzNk44iMOzTilhEeJ/R6GpXrBjtOYPUgKtcviVA4U9jpIS4UOXlXaaG4WOE4Bc5YaC2T0gU6T5DkXaXXX2/EJNtILqikjHPm2EPRkaH412YYkmUe4sNgsw9D64I/HXudBAKDVWqxmaa22DsROQNcLSZKeTFRGm6csbURja1iEs3WJtvtfjCx2rQUeV7Ig8lvxwLkOkVu7W2c9zaOF8q/GA+j2cRtj1jdnFvjRrCmOtAYhiSwG8BX3f5/SXDjBhQLry5G29HzwzcdEMtC4AUj3aQqvRYlNOy3oZ5MwFJl/oWpdG9lGVEuUqXHOSi3d7hk1qZr/nZriwwCruyB1sBW2HvjQ2HZZZZdN7CYtFSbf1Eq3WIpmlTNKs4DiOuJJgwGquw4OwRxjbmILlf58hs=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Job_Number = _t, VoidPK = _t, #"Cost Type" = _t, #"Base Amount" = _t]),
        chgTypes = Table.TransformColumnTypes(Source,{{"Job_Number", type text}, {"VoidPK", type text}, {"Cost Type", type text}, {"Base Amount", type number}}),
        pivotCostType = Table.Pivot(chgTypes, List.Distinct(chgTypes[#"Cost Type"]), "Cost Type", "Base Amount", List.Sum),
        addGrandTotal = Table.AddColumn(pivotCostType, "grandTotal", each List.Sum({[LABOUR],[MATERIALS],[SCP]}))
        addGrandTotal
    Pete
