Power Query - Aggregate and transpose help
- 4 years ago
Hi cottrera ,
I've included the code to do what you want below, but the first question is: why do you want to do this? The original format of your data is the optimum and most efficient structure for reporting. Using expensive resources to move the structure further away from optimum is not generally considered best practice.
The answer to your actual question:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("vZXBbtswDIbfJedCEClRoo5pFwTFMmxovO1Q9NbLTj30/YGRcmDJk6J4xbDTbxsfSIr8RT8/7x5/fjo8ULS7u53Kj7dfr+/yfNrff/3+JA/O7V7uLlhwXjGRBgOwFechcx5ucEyZY2o47wvGlMOJfBSL8YIdTgGUUmkoDM5QFc9yjmd5fIoRxyUxsWIqtxJTyAcRGQTcyn2+BwryRaVN7JyJ9AESSZ2gMia1ShdylW4J+mU/HZ4e96dz7qSxWMFpNmJqjRirkzNk44iMOzTilhEeJ/R6GpXrBjtOYPUgKtcviVA4U9jpIS4UOXlXaaG4WOE4Bc5YaC2T0gU6T5DkXaXXX2/EJNtILqikjHPm2EPRkaH412YYkmUe4sNgsw9D64I/HXudBAKDVWqxmaa22DsROQNcLSZKeTFRGm6csbURja1iEs3WJtvtfjCx2rQUeV7Ig8lvxwLkOkVu7W2c9zaOF8q/GA+j2cRtj1jdnFvjRrCmOtAYhiSwG8BX3f5/SXDjBhQLry5G29HzwzcdEMtC4AUj3aQqvRYlNOy3oZ5MwFJl/oWpdG9lGVEuUqXHOSi3d7hk1qZr/nZriwwCruyB1sBW2HvjQ2HZZZZdN7CYtFSbf1Eq3WIpmlTNKs4DiOuJJgwGquw4OwRxjbmILlf58hs=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Job_Number = _t, VoidPK = _t, #"Cost Type" = _t, #"Base Amount" = _t]), chgTypes = Table.TransformColumnTypes(Source,{{"Job_Number", type text}, {"VoidPK", type text}, {"Cost Type", type text}, {"Base Amount", type number}}), pivotCostType = Table.Pivot(chgTypes, List.Distinct(chgTypes[#"Cost Type"]), "Cost Type", "Base Amount", List.Sum), addGrandTotal = Table.AddColumn(pivotCostType, "grandTotal", each List.Sum({[LABOUR],[MATERIALS],[SCP]})) in addGrandTotalPete
Hi cottrera ,
addGrandTotal
Pete
Hi BA_Peter thank you for your response . The code works perfectly. In response as to why I am doing this. Its for a colleage and I will menstion your best practice comments
RIchard
