jishnubhattacha's avatar
1 month ago
Power BI M-Query with TVF execution issue
Dear Team,
I have designed a report in Power BI it is art of a Tableau to Power BI migration. I have separated the visuals among three pages with  drill through option. It is working as expected but facing a slowness. So  I think to use a benefit of M-Query with  TVF passing parameter values to make pushdown query. parameter value is a single parameter and accept a comma separated values from 1st page visual. However I have created TVF. TVF is executing properly in DB side. But when I create a bind parameter and associated with my  column make it text and enable multi option to get multiple values . Now I write a code snippet
VP=if P_param= null or P_param= "" or P_param= "XXXX" then "ALL"
else if Value.Is(P_param, type list) then Text.Combine(List.Transform(P_param, Text.From), ",")
else Text.From(P_param),
SQL_Query = "SELECT * FROM MY_TVF('" & VP & "')",
Source = #table({"Generated_SQL"}, {{SQL_Query}})
Source
This code has been written to  check  whether the selected parameter from visual VP=1001  is passing properly in TVF.
Objective: 1. SELECT * FROM MY_TVF('1001,1002') (if multiple value selected from visual)
                  2. SELECT * FROM MY_TVF('1001')  (if single value is sent)
But when I click  from visual using drill through feature  the TVF is showing always
SELECT * FROM MY_TVF('ALL') -
The drill through  fields when I put in the 2nd page then it is showing proper values . but it is not passing in the TVF so  query is not executed it returns blank.
My objective is from 1st page matrix visual when I select record one by one accordingly the value will pass and show the result.
In matrix 1st column is A1 and A2 is the second column. A1 & A2 are also in drillthrough bucket.
A1 can contain multiple A2.  so when one A1 is selected then multiple comma separated A2 has been passed in TVF.  A2 is an id field. and when A2 column it self selected then single value will pass. But value is not passing and I am not getting the benefit of query pushdown by M-Parameter.  The A2 column is parameter binded. it is a text field.  P_Param= A2. (bind to A2) . multiple accepted.
could you please check  and provide any  assistance?
I have tried all possible options but no results has been encountered.
Regards
Jishnu Bhattacharya
  • Hi jishnubhattacha​ ,
    Yes, your observation is reasonable. Dynamic M Query Parameters are intended to push slicer/filter selections into DirectQuery source queries. Microsoft does not state that they are completely unsupported in Composite models.
    In a Composite model, an Import-mode table can coexist with DirectQuery tables. However, if the parameter-bound query is affected by the Import table's filter context, the parameter may not be pushed to the source as expected.
    Therefore, having the visual based only on DirectQuery tables is a good test. If the same parameter works in that isolated DirectQuery visual, but stops working when the Import date table participates in the filtering, the issue is more likely related to filter propagation/storage-mode interaction rather than Composite mode itself.
    Chaithanya.
  • v-kathullac's avatar
    v-kathullac
    Thank you for reaching out to Microsoft Fabric Community Forum, Below are the few points which can resolve your issue. Let us know if you need any further assistance.
    The behavior described appears to be related to a limitation of Dynamic M Query Parameters with Drill-through, rather than an issue with the TVF or the parameter expression.
    Your requirement of passing a single value such as 1001 or multiple values such as 1001,1002 to the TVF is supported by Dynamic M Query Parameters when the parameter is directly driven by a slicer/filter with multi-select enabled.
    However, Drill-through/Cross-drill filters are not supported as inputs to Dynamic M Query Parameters. Therefore, although A2 is correctly shown in the Drill-through filter context on the second page, that value is not being passed to P_param. As a result, your M expression evaluates to ALL, producing:
    This explains why the Drill-through page displays the correct A2 value while the TVF still receives ALL. As a validation, please test the same P_param using a slicer/filter directly bound to A2:
    • Single selection → MY_TVF('1001')
    • Multiple selection → MY_TVF('1001,1002')
    If this works, it confirms that the TVF and Dynamic M parameter are functioning correctly and that the issue is specifically the Drill-through → Dynamic M parameter handoff.
    For the required behavior of selecting A1/A2 in Page 1 and automatically passing the selected A2 value(s) to the TVF after Drill-through, Dynamic M Query Parameters cannot currently provide that integration. The practical options are to use a parameter-bound slicer/filter on the destination page or redesign the query/filtering approach so the parameter value is available before the source query is executed.
    One additional point: the current step : Source = #table({"Generated_SQL"}, {{SQL_Query}})
    only creates a table containing the SQL text. It does not actually execute the TVF or confirm query pushdown. The actual SQL connector/source step needs to invoke the TVF to validate database-side execution and pushdown.
    Microsoft documents Drill-down and Cross-drill filters as unsupported scenarios for Dynamic M Query Parameters:
    Microsoft Learn – Dynamic M Query Parameters
    Chaithanya.
    v-kathullac
    Thank you for providing the detailed requirement. Based on the described scenario, the two visuals can remain on the same page; however, there is a limitation with using a Matrix row selection directly to populate a Dynamic M Query Parameter.
    Dynamic M Query Parameters cannot use a Matrix click/cross-highlighting interaction to dynamically pass the selected ProductID values to the M parameter. The supported approach would be to use a Category/ProductID filter or slicer as the parameter-driving field. For example:
    • When ProductID 1 is selected, the M parameter receives 1 and the TVF executes for ProductID 1.
    • When Category A1 is selected, the corresponding ProductIDs {1,2,3,4,5} can be passed through a multi-select M parameter to the TVF.
    • When Category A2 is selected, {10,11} can be passed to the TVF.
    The TVF result can then be displayed in the second visual on the same page, so a drill-through page is not required. However, if the requirement is specifically to click the Category/Matrix row and automatically pass the corresponding ProductID list to the M parameter without using a slicer or filter, this interaction is not supported with Dynamic M Query Parameters.
    Therefore, for the current requirement, we recommend using a Category/ProductID filter or slicer to drive the multi-select M parameter, which will then pass the selected ProductID values to the TVF and return the required data to the visual on the same page.
    Chaithanya.
    v-kathullac
    As we haven’t heard back from you, we wanted to kindly follow up to check if the solution provided for the issue worked? or Let us know if you need any further assistance?
    Chaithanya
  • Dear Chaithanya,
    Thank you for the explanation. So you have mentioned that passing M-query parameter to drill through page is currently not supported in Power BI.
    OK no issue. I will put the  visual where I applied pushdown technique in same page. say page 1.
    Now I am giving you a diagrammatic approach of my objective
    I am trying to pass product id=1 when I click on 1st record where A1/1 so 1 is passed in bind parameter. consider productid is bind with testparam
    when click on only category A1 then I want to pass product id as 1,2,3,4,5 and TVF will accept
    this and execute and furnish the result.  Now I want to keep both visual in same page no drillthrough. Please guide me how can I accomplish the query pushdown with M-Query by parameter bind using TVF.
  • Dear Chaitanya,
    Thank you for the update. I had divided the visuals into multiple pages like drill through option and introduce a slicer in top of the second page. so the matrix selection automatically filtered out the designated and relevant values into slicer and click on slicer I have executed dynamic M-query with TVF first but TVF has one concern while passing multiple string values as a parameter. So I have created one standalone view and then use the M-query parameter in where condition with Text.Combine approach and get the result with optimum performance rather I can say controlled execution.
    But just confirm this approach  is solely working in direct query mode only. Not in Composite mode.
    Because I have a date range slicer which  takes value from a static table which is in import mode and rest of the queries are in direct query mode. main visual get filtered based on date range so dynamic M-Query is not working there but the report which is completely designed in direct query  is working properly with  M-Parameter.
    But Microsoft documentation is not written that M-Query does not work in composite model cases. so if I want to use it in composite model then that visual is not dependent on any static import tables.
    Please confirm my understanding is proper or not according to my observation and my experience of facing issues.
    Regards
    Jishnu Bhattacharya
    v-kathullac
    Chaithanya.
    v-kathullac
    Chaithanya
