3 years agoNot applicable
Power Bi help
I'm trying to do a formula where if the weekly hours are compared to the standard contract hours.
The formula isnt working for the sum of hours. If it is 37.5 or less than 40 it says hours sufficient however it isn't working.
How do I do a weekly count as the sum isnt working.
1 Reply
- KNPSuper User
Hi Anonymous,
You've posted in the Power Query forum, do you want/need this to be a Power Query solution or would DAX be ok?
Please paste data, not just a screen shot. You'll get an answer much faster with usable data posted.
