4 years agoNot applicable
Power BI doesn't allow connection with OAuth2 to SQL Source
Hi all, I met frustrating problem recently for which I'm seeking a help: The situation: I have a dataset in load regime with connection to a single source - SQL for which I use the Sql.Datab...
2 years agoNot applicable
Hi! Can you fix the issue with OAuth2.0? I have the same issue, i change my O365 password and is impossible to change on connetions, even if i created a new one, i can't change it.
