619SK
Helper II
2 years agoPower BI Conditional Base filter calculation
Im not able to find the neasur to calculate below condition in measure , i have updated sample Final expected data to be on bi
- 2 years ago
- It's because of the order in which they are listed. 66 is greater than 30 so a match is found and no further rules will be evaluated for that value. They should be evaluated in descending order.
= if [Age_c] ="0-15" and [Count] >=50 then 90 else if [Age_c] = "0-15" and [Count] >= 30 then 95 else 100
619SK
Helper II
2 years agoThanks for query
Suppose my count result is 0-15 =66
my query is = if [Age_c] ="0-15" and [Count] >=30 then 95, if [Age_c] = "0-15" and [Count] =>50 then 90 else 100
Here ideally expected result for 66 count is 90 but i'm getting result of 95 point.
I'm getting first query as result.
- jennratten2 years ago
