Not able to make connection using direct query in SQL
I am using direct query in power bi to connect to my SQL database in Power BI. I have my SQL database on a shared server and I am able to make the connection from my desktop to the SQL server using power BI. But after I publish my report Power BI asks me to enter the SQL server credentials to connect to my database and after I enter the cerdentials it is just continously loading and not connecting to my data base.
- Anonymous9 years ago
siddhantk989 If you use Azure SQL DB or Warehouse you don't need a gateway as those are cloud services. Since it sounds like you are on-premises, you need a gateway. And the personal gateway doesn't support Direct Query, only the OPD Gateway does.
As to your other question, "it depends":
If you need the absolute latest data - use DQ
If you have issues with pushing data into the cloud - use DQ
Would the model size exceed 1GB in the Desktop - use DQ
If the load and processing times to import the data take to long - use DQ
DQ may require additional performance monitoring depending on number of users, and will most likely be a little slower due to the communication latency. You also have some restrictions based on some measures that aren't supported, and the Desktop limits the data manipulation you can do.
I use both import and DQ, it largely depends on the scenario.
Easy to test, just copy your PBIX, leave the original in DQ and change the connection type in the new one to import. See how long it takes to load, change things, etc.
- AnonymousNot applicable
siddhantk989 Have you installed the On Premises Data Gateway? You shouldn't be prompted for those creds using Direct Query. You would need the datasource already set up and it should either show the gateway online or offline. The personal gateway does not support direct query.
- siddhantk989
Helper III
Hi Anonymous,
Thanks for the update sir. I thought that if we are using direct query we do require any gateway for the connection. I would also like have your suggestion on what would you recommend to use if we have around 3 million of records. Should we continue with the Direct query or switch to the import feature?
