Need help with Power Query web/URL
I have the below Power Query which results in a table with financial data from Yahoo Finance for 3 specific securities (Microsoft, Apple, and Disney in this case). I want to build a solution which looks at another worksheet which has a list of security symbols; the solution would then change the below query to match the security symbols in that worksheet. To clarify, neither the end user not I as the developer should have to "manually" modify the query.
I have not found a way to "code this in VBA". Can you point me in the right direction or point out books, blogs, Youtubes, etc.
Thank you all in advance.
Here is the query M-code (I did build this with the PQ GUI):
Source = Web.Page(Web.Contents("https://finance.yahoo.com/quotes/MSFT,AAPL,DIS/view/v1")),
Data0 = Source{0}[Data],
#"Changed Type" = Table.TransformColumnTypes(Data0,{{"Symbol", type text}, {"Last Price", type number}, {"Change", type number}, {"Chg %", Percentage.Type}, {"Currency", type text}, {"Market Time", type text}, {"Volume", type text}, {"Shares", type text}, {"Avg Vol (3m)", type text}, {"Day Range", type text}, {"52-Wk Range", type text}, {"Day Chart", type text}, {"Market Cap", type text}, {"", type text}})
#"Changed Type"
- lbendlin
you need to use RelativePath, and construct the symbol list separately (or source it from your Excel etc)
let Symbols = {"MSFT","AAPL","DIS"}, Source = Web.Page(Web.Contents("https://finance.yahoo.com/quotes/",[RelativePath= Text.Combine(Symbols,",") & "/view/v1"])), Data0 = Source{0}[Data], #"Changed Type" = Table.TransformColumnTypes(Data0,{{"Symbol", type text}, {"Last Price", type number}, {"Change", type number}, {"Chg %", Percentage.Type}, {"Currency", type text}, {"Market Time", type text}, {"Volume", type text}, {"Shares", type text}, {"Avg Vol (3m)", type text}, {"Day Range", type text}, {"52-Wk Range", type text}, {"Day Chart", type text}, {"Market Cap", type text}, {"", type text}}) in #"Changed Type"Here's all the documentation you will ever need 🙂 Web.Contents - PowerQuery M | Microsoft Learn
- BoaRolandRegular Visitor
Thank very much lbendlin,
Can I use a named range in my Excel to hold the symbol list and then reference that named range in the Power Query code? I'm still fairly new with M-syntax/code.
How can I use the set the variable "Symbols" to equal the named range "Secs"?
Or maybe I should refer to the named range in the Text.Combine part??
I tried various syntax, but all resulted in errors.
Thank you very much in advance.
Roland
- lbendlin
Can I use a named range in my ExcelThe preferred way is to use a table. Then use Text.Combine on the relevant column of that table source.
Thank you very much for the info on RelativePath.
Roland
