aravind2409's avatar
aravind2409
3 years ago
Need help with manually calculating difference between two percentage or numbers and cond. formattin
Hi All,
I have a data like this. Need help with subtracting Jan - Feb and Feb - March like wise and show the difference. Kindly help this is bit urgent. Would be great if some one can help on this
  • mussaenda's avatar
    mussaenda
    Hi aravind2409 ,
    Since you already have the previous month on your data,
    do a measure of resolved count / resolved count - previous month then change the data type to percentage
    • aravind2409's avatar
      aravind2409
      Hello ,
      Thanks for checking. I tried and its not working.
      My requirement is in Jan percentage is 83.83 and Feb is 85.07 i want the difference between two (85.07-83.33). Kindly help. Thanks in advance for your help
        mussaenda
        It was not indicated on your first post that you need the percentage value difference.
        Anyway, i had no idea how the Total Resolved % is claculated.
        but if this is what you want to achieve,
        use  the previousmonth function for the % and the subtract them
        Resolved % LM =
        CALCULATE(
            [RESOLVED %],
            PREVIOUSMONTH('Table (2)'[Date]),
            REMOVEFILTERS('Table (2)'))
