rmahadik's avatar
rmahadik
4 years ago
Need help to create a list using a custom function and add it has column in table.
Hi Experts,
I am trying to perform a iterative logic to get the row count of each table in Decision_Table.
Decision_Table contains column with name Data_DB having tables. So I planned to write a custom function which will first generate a list of row count of each table in column Data_DB of Decision_Table and then add list as column in Decision_Table.
However I'm not able to create the list and getting below error. Please advise how to create a list if output is coming in iterative way. Or else please advise on solution for above requirement.
output:
  • Hi rmahadik ,
    On your table with the nested table column, just add a new custom column with the following:
    Table.RowCount([Data_DB])
    Pete
