JiayiHe炮饱饱
3 years agoRegular Visitor
NEED HELP! Problem during quick measure
Greeting , Need support on below .Thanks in advance ! I am using quick measure ,but found error massage as screenshot. It's for attrition report, need update monthly. Strangely, the measure co...
v-yalanwu-msft
3 years agoHi, JiayiHe炮饱饱 ;
Sorry you provided too little information to determine the cause of the error and didn't see your formula error message
please provide some sample data in your tables (exclude sensitive data) with Text format and your expected result with backend logic and special examples. It is better if you can share a simplified pbix file. You can refer the following link to upload the file to the community. Thank you.
How to upload PBI in Community
Community Support Team _ Yalan Wu
