KuntalSingh
Helper V
3 years agoNeed Help on Excel power query editor by using M code
I have two column Unique key and Reference Key 3 Reference key 3 colunm have some blank rows and need unique key colunm value where in reference key is blank by using M code. Unique key ...
- 3 years ago
Ok. This code takes the highest [Reference ky 3] value to fill in the blanks:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("jZDLCsIwFER/Rbou9Wbueym4duG29P9/w9S0IJhaV4GcORMm8zzgcb88b1dEgjPKfg7jIGAJLjQs46/YCd5a9B0rmoCbUQo2lsnRY62WJioTCIzQUIRVoikm7CJ2nGmNlaBrC6vrcebUdmo2xcfbbjW3212y2qHsaIudrE4OQQSjYS9af4u7+P/LTpH0HPlytKzLlhc=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Unique Key" = _t, #"Reference key 3" = _t]), repBlankNull = Table.ReplaceValue(Source,"",null,Replacer.ReplaceValue,{"Reference key 3"}), //Relevant steps from here ------> groupRows = Table.Group(repBlankNull, {"Unique Key"}, {{"data", each _, type table [Unique Key=nullable text, Reference key 3=nullable text]}}), addNestedRef3 = Table.TransformColumns( groupRows, { "data", (x)=> Table.AddColumn( x, "RefKey3", each if [Reference key 3] = null then List.Max(x[Reference key 3]) else [Reference key 3] ) } ), expandData = Table.ExpandTableColumn(addNestedRef3, "data", {"Reference key 3", "RefKey3"}, {"Reference key 3", "RefKey3"}) in expandDataSummary:
-1- groupRows = Group By [Unique Ref] and add an All Rows aggregated column called "data"
-2- addNestedRef3 = Add a column to the nested table that gets the highest [Referece key 3] value if the cell is null
-3- expandData = Expand the nested table columns back out again
Example query output:
Pete
KuntalSingh
Helper V
3 years agoNo,
Lookup unique_key to return the reference key 3 where the ref key are blank.
If we do it manually used Vlookup formula: =Vlookup (Unique_Key,Rance( Unique_Key & reference key3 ) Column number in the range containing the return value, 0).
Hope you understand my ask
KuntalSingh
Helper V
3 years agoSample Data,
| Unique Key | Reference Key 1 | Reference Key 2 | Reference key 3 |
| 2ND RA/2892398128923981 | 42348310 | ||
| 2ND RA/2892398128923981 | 42348313 | ||
| 2ND RA/2892398128923981 | 42348315 | ||
| 00328980146 | 42348471 | ||
| NMPPL-SIK/OFF/RT27916712 | 42349073 | ||
| NMPPL-SIK/OFF/RT27917080 | 42349107 | ||
| 159227660942 | 42349938 | ||
| 159227660942 | 42349952 | ||
| ATI/23-24/4628422284 | 42350916 | ||
| 8321127883461 | 5943992158 | ||
| 20.01.202328585286 | 5946437446 | ||
| 20.01.202328585286 | 5946437658 | ||
| 10.02.202328585286 | 5946443575 | ||
| 10.02.202328585286 | 5946443699 | ||
| 10.02.202328585286 | 5946443705 | ||
| 20.02.202328587403 | 5946586447 | ||
| 7045127883461 | 5946789505 | ||
| 08.01.202328576858 | 5946853727 | ||
| 08.01.202328576858 | 5946853728 | ||
| 22028585286 | 5946954412 | ||
| 7069228428832 | 5947154833 | ||
| 7069428428832 | 5947155105 | ||
| 7070028428832 | 5947155230 | ||
| DOM2023240146128428832 | 5947256693 | ||
| 9128482429 | 5947289137 | ||
| 9228482429 | 5947289437 | ||
| 9528482429 | 5947291344 | ||
| 9428482429 | 5947291348 | ||
| 10028482429 | 5947291431 | ||
| 9728482429 | 5947291434 | ||
| 9928482429 | 5947291437 | ||
| 9828482429 | 5947291510 | ||
| 10128482429 | 5947402859 | ||
| 10228482429 | 5947402866 | ||
| DOM2023240150228428832 | 5947403044 | ||
| DOM2023240150428428832 | 5947403045 | ||
| DOM2023240153528428832 | 5947403048 | ||
| DOM2023240150428428832 | 5947403105 | ||
| DOM2023240148628428832 | 5947403129 | ||
| DOM2023240148728428832 | 5947403191 | ||
| DOM2023240148828428832 | 5947403192 | ||
| DOM2023240149228428832 | 5947403195 | ||
| DOM2023240153128428832 | 5947403345 | ||
| DOM2023240153328428832 | 5947403346 | ||
| DOM2023240169828428832 | 5947403482 | ||
| DOM2023240153228428832 | 5947403485 | ||
| DOM2023240153428428832 | 5947403489 | ||
| DOM2023240147828428832 | 5947405163 | ||
| DOM2023240148028428832 | 5947405165 | ||
| DOM2023240147928428832 | 5947405222 | ||
| DOM2023240148128428832 | 5947405225 | ||
| DOM2023240170628428832 | 5947405226 | ||
| DOM2023240151928428832 | 5947405487 | ||
| DOM2023240153728428832 | 5947405489 | ||
| DOM2023240153828428832 | 5947405682 | ||
| DOM2023240154128428832 | 5947405683 | ||
| DOM2023240154328428832 | 5947405684 | ||
| DOM2023240169928428832 | 5947405685 | ||
| DOM2023240154228428832 | 5947405686 | ||
| DOM2023240154428428832 | 5947405688 | ||
| DOM2023240169928428832 | 5947405689 | ||
| SEPL/202/23-2428601947 | 5947472159 | ||
| SEPL/203/23-2428601947 | 5947472322 | ||
| SEPL/204/23-2428601947 | 5947487589 | ||
| SEPL/200/23-2428601947 | 5947518405 | ||
| SEPL/201/23-2428601947 | 5947518407 | ||
| SEPL/205/23-2428601947 | 5947540367 | ||
| SEPL/206/23-2428601947 | 5947540369 | ||
| INV/04328684753 | 5947701395 | ||
| 1J/5/50069/23-2429112976 | 5947760402 | ||
| 1J/5/50068/23-2429112976 | 5947760403 | ||
| DOM2023240047528428832 | 5947764671 | ||
| DOM2023240150328428832 | 5947764675 | ||
| DOM2023240047528428832 | 5947820731 | ||
| 1J/5/50081/23-2429112976 | 5947878329 | ||
| 1J/5/50082/23-2429112976 | 5947879253 | ||
| 09228482429 | |||
| 09228482429 | |||
| AS/IOCL/23-24/0828914923 | |||
| 09228482429 | #N/A | ||
