Need Help on Excel power query editor by using M code
I have two column Unique key and Reference Key 3
Reference key 3 colunm have some blank rows and need unique key colunm value where in reference key is blank by using M code.
Unique key Reference Key 3
7595735GST/KNP/2022/003 41204070
2798337127983371 41154547
2798337127983371 41154529
279917281408 41097136
27958936A-092 41063446
27959015MAU 41062015
279568921408 41059635
27550294VNSDO/04/23-24 40909663
27759530RTS/1254/21-22 40856544
27659853LV/2122/UP/112 40837604
28883364F20000024538
28883364F20000024544
28883336F20000022361
28883364F20000022650
28883364F20000024537
28883364F20000022894
28883364F20000024210
28883364F20000024211
28883364F20000022893
28883336F20000027768
28883336F20000027691
28883336F20000027769
28883336F20000027770
28883336F20000027692
Ok. This code takes the highest [Reference ky 3] value to fill in the blanks:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("jZDLCsIwFER/Rbou9Wbueym4duG29P9/w9S0IJhaV4GcORMm8zzgcb88b1dEgjPKfg7jIGAJLjQs46/YCd5a9B0rmoCbUQo2lsnRY62WJioTCIzQUIRVoikm7CJ2nGmNlaBrC6vrcebUdmo2xcfbbjW3212y2qHsaIudrE4OQQSjYS9af4u7+P/LTpH0HPlytKzLlhc=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Unique Key" = _t, #"Reference key 3" = _t]), repBlankNull = Table.ReplaceValue(Source,"",null,Replacer.ReplaceValue,{"Reference key 3"}), //Relevant steps from here ------> groupRows = Table.Group(repBlankNull, {"Unique Key"}, {{"data", each _, type table [Unique Key=nullable text, Reference key 3=nullable text]}}), addNestedRef3 = Table.TransformColumns( groupRows, { "data", (x)=> Table.AddColumn( x, "RefKey3", each if [Reference key 3] = null then List.Max(x[Reference key 3]) else [Reference key 3] ) } ), expandData = Table.ExpandTableColumn(addNestedRef3, "data", {"Reference key 3", "RefKey3"}, {"Reference key 3", "RefKey3"}) in expandDataSummary:
-1- groupRows = Group By [Unique Ref] and add an All Rows aggregated column called "data"
-2- addNestedRef3 = Add a column to the nested table that gets the highest [Referece key 3] value if the cell is null
-3- expandData = Expand the nested table columns back out again
Example query output:
Pete
- BA_Pete
Hi KuntalSingh ,
You can create a new custom column like this:
if [Reference Key 3] = null then [Unique Key] else [Reference Key 3]Pete
- KuntalSingh
Helper V
Hi Pete
My ask is
Reference key 3 colunm have some blank rows and need reference key on the basis of lookup from colunm Unique key by using M code. If i do it manuall in excel I used formula VLOOKUP([@[Unique_Key]],AA2:AD6546,4,0)
where AA is Unique Key column and AD is Reference Key 3 column
- BA_Pete
Can you provide a copyable example of all the tables that you're referring to please?
It sounds like you have two separate tables but you've only provided an example of one of them.
You can paste your examples directly from Excel into a reply window here to ensure formatting stays intact.
Pete
