3 years agoNot applicable
Need help in data refresh for power BI for adding incremental data in current available data
I have some some data available in table format & another data from web source.
Is there any way I can add data from the web source into already available dataset.
basically I want to do,
y = y + x
where x is variable data with time & it should add upon data y.
I need to use use it in Power BI.
- AlB
Hi Anonymous
Can you share some sample data for both tables and show with an example based on that data what exactly the requirement is?
Please accept the solution when done and consider giving a thumbs up if posts are helpful.
- AnonymousNot applicable
Hi AlB, actually its a production data for a month, & web source should refresh & should add data to this month data.
