need help - Power query or M code solution needed
- 1 year ago
Hi ashwinkolte,
Hi ashwinkolte,
Thank you for reaching out to the Microsoft fabric community forum. Thank you jgeddes, and lbendlin, for your inputs on this issue.
After thoroughly reviewing the details you provided, I was able to reproduce the scenario, and it worked on my end. I have used it as sample data on my end and successfully implemented it.
I am also including .pbix file for your better understanding, please have a look into it:
If this post helps, then please give us ‘Kudos’ and consider Accept it as a solution to help the other members find it more quickly.
Thank you for using Microsoft Community Forum.
- ashwinkolte1 year ago
Helper III
First of all thanks for responding
I saw the PBIX file and M code . if I am not wrong this code is using hardcoded column names . What if there there come additional ones which would come in the future in the input ? Will this work ?
#"Replaced Value" = Table.ReplaceValue(#"Transposed Table","",null,Replacer.ReplaceValue,{"Column1"}),
#"Replaced Value1" = Table.ReplaceValue(#"Replaced Value","",null,Replacer.ReplaceValue,{"Column2"}),
#"Replaced Value2" = Table.ReplaceValue(#"Replaced Value1","",null,Replacer.ReplaceValue,{"Column3"}),
#"Replaced Value3" = Table.ReplaceValue(#"Replaced Value2","",null,Replacer.ReplaceValue,{"Column4"}),
#"Transposed Table1" = Table.Transpose(#"Replaced Value3"),
#"Renamed Columns" = Table.RenameColumns(#"Transposed Table1",{{"Column1", "Monitor"}, {"Column4", "Monitor_group"}, {"Column2", "Usergroup"}, {"Column3", "Poller"}, {"Column5", "Contact"}}),
#"Filled Down" = Table.FillDown(#"Renamed Columns",{"Poller", "Column6"}),
#"Reordered Columns" = Table.ReorderColumns(#"Filled Down",{"Monitor", "Monitor_group", "Usergroup", "Poller", "Contact", "Column6"}),
#"Renamed Columns1" = Table.RenameColumns(#"Reordered Columns",{{"Column6", "Portnumber"}}),
#"Reordered Columns1" = Table.ReorderColumns(#"Renamed Columns1",{"Monitor", "Monitor_group", "Usergroup", "Poller", "Portnumber", "Contact"})
#"Reordered Columns1"- v-kpoloju-msft1 year ago
Hi ashwinkolte,
Thank you for your detailed observation. You are right to raise this concern.The current M code relies on hardcoded column names such as "Column1", "Column2", etc. This method can lead to issues if the input file structure changes in the future (e.g., new columns are added or the column order changes), as the transformation steps may not function as expected or may even cause errors.
To make the ReplaceValue step future proof and apply it across all columns dynamically (including any that may be added later), you can use the code below. It will replace empty strings ("") with null across the entire table without needing to update the column list manually:
ReplaceBlanksWithNulls = Table.ReplaceValue( #"Transposed Table", "", null, Replacer.ReplaceValue, Table.ColumnNames(#"Transposed Table") )
This ensures that any new columns added to the source data will automatically be included in the transformation no code changes needed.If this post helps, then please give us ‘Kudos’ and consider Accept it as a solution to help the other members find it more quickly.
Thank you for using Microsoft Community Forum.- v-kpoloju-msft1 year ago
Hi ashwinkolte,
