Thangavel_Raju
4 years agoFrequent Visitor
Multiple conditions using cell reference in power query
Dear Friends, The first table below is the master data and the second is the transaction data. First table contains salary slab, performance rating as exceptional, effective, compenent and ineff...
- Anonymous3 years ago
Hi Thangavel_Raju ,
Based on your example, I think your interval starts and ends like this, right?
If so, here's the workaround.
1.Unpivot the columns.
2.Merge Table2 with Table1.
3.Expand it.
4.Add a custom column, return 1 if the filter condition is met, otherwise 0.
5.Filter out 0 and you can get the percentage matching based on the performance type and value range.
Stephen Tao
wdx223_Daniel
4 years ago
Master = Table.Buffer(Excel.CurrentWorkbook(){[Name="Master"]}[Content]),
Salary = Excel.CurrentWorkbook(){[Name="Salary"]}[Content],
Custom1 = Table.AddColumn(Salary,"Increment",each Record.FieldOrDefault(Table.Last(Table.RemoveLastN(Master,(x)=>x[Salary slab]>[BASIC])),[Performance Rating],0)*[BASIC])
Custom1- Thangavel_Raju4 years agoFrequent Visitor
Hi Daniel,
Thank you so much. I shall try the solution and would come back to you.
Regards
