1 year agoNot applicable
Merging rows and using row values as both column headers and row values
I have a table that has a column filled with questions, and another column with applicable respoonses to those questions. I'm hoping I can transform this table using Power Query so that each question is a column header and the value in that column is the response. A sample of the table as-is now and what I'd like for it to look like is posted below:
Table now:
| Company | Question | Response |
| Acme | Question 1 | Yes |
| Acme | Question 2 | No |
| Acme | Question 3 | 50 |
| Acme | Question 4 | Blue |
My desired result:
| Company | Question 1 | Question 2 | Question 3 | Question 4 |
| Acme | Yes | No | 50 | Blue |
Just Pivot with no aggregation
Table.Pivot(#"Previous Step", List.Distinct(#"Changed Type"[Question]), "Question", "Response")
- ronrsnfldSuper User
Table.Pivot(#"Previous Step", List.Distinct(#"Changed Type"[Question]), "Question", "Response")- AnonymousNot applicable
Thanks this worked!
- Akash_VarunaSuper User
Hi Anonymous , Could you please try this
- Select "Company" as the grouping column, "Question" as the column to pivot, and "Response" as the values.
- Go to the "Transform" tab and click "Pivot Column."
- In the dialog, set "Values Column" to "Response" and "Column to Pivot" to "Question."
If this post helped please do give a kudos and accept this as a solution
Thanks In Advance
Thanks for the response - I didn't get a chance to try as the previous response worked.
