Max Date Math Issues In Power Query
- 5 years ago
Hi asjones,
Since you need 2 columns based on the max date,I would suggest you first create a column to get the max date,using below M codes:
=Table.Max(#"Changed Type","Date")Then create another 2 columns to get 7days and 14days:
=if [Date]>Date.AddDays([Max date.Date],-7) then "7 days" else null=if [Date]>Date.AddDays([Max date.Date],-14) then "14 days" else nullAnd you will see:
For the related .pbix file,pls see attached.
KellyDid I answer your question? Mark my reply as a solution!
edhansthanks for the reply this looks fairly processor intensive ...especially as I wanted to also do a 14 day version then combine them.... it seems like this is a case where Excel may be better? What do you think?
It depends. DAX may be better. Depends on where you need the output to be. This is the same thing in a DAX Calculated Column. This is one of the rare times I'd recommend a calculated column if you cannot do this efficiently in your source data.
DAX Version =
VAR varMaxDate = MAX('Table'[Date])
IF(
varMaxDate -7 < 'Table'[Date],
"7 Days",
