Max Date Math Issues In Power Query
- 5 years ago
Hi asjones,
Since you need 2 columns based on the max date,I would suggest you first create a column to get the max date,using below M codes:
=Table.Max(#"Changed Type","Date")Then create another 2 columns to get 7days and 14days:
=if [Date]>Date.AddDays([Max date.Date],-7) then "7 days" else null=if [Date]>Date.AddDays([Max date.Date],-14) then "14 days" else nullAnd you will see:
For the related .pbix file,pls see attached.
KellyDid I answer your question? Mark my reply as a solution!
edhansthanks for the reply this looks fairly processor intensive ...especially as I wanted to also do a 14 day version then combine them.... it seems like this is a case where Excel may be better? What do you think?
- edhans5 years ago
It depends. DAX may be better. Depends on where you need the output to be. This is the same thing in a DAX Calculated Column. This is one of the rare times I'd recommend a calculated column if you cannot do this efficiently in your source data.
DAX Version = VAR varMaxDate = MAX('Table'[Date]) RETURN IF( varMaxDate -7 < 'Table'[Date], "7 Days", "-" )
