shocktech
3 years agoNew Member
Match and Extract String from List using Power Query
I am trying to extract the Primary SMTP address fomr the proxyAddress attibute in ADDS. When expanded the proxyAddress attribute is a list. An Exmple of the onctent might be as follows: smtp: jo...
- 3 years ago
Hi shocktech
Do you mean each row in the text you show is an element in a list? And by list you refer to a PQ list, for example {1, 2, 3, 4} ?
Please accept the solution when done and consider giving a thumbs up if posts are helpful.
- 3 years ago
Place the following M code in a blank query to see the steps of a potential solution:
let Source = { "smtp: [email protected]", "SMTP: [email protected]", "X500:/o=VHI/ou=First Administrative Group/cn=Recipients/cn=bloggs_j", "x500:/o=ExchangeLabs/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Recipients/cn=744b0ca795fa4892a71b247bcd3009f3-bloggs_j"}, findSMTP_ = List.Select(Source, each Text.Contains(_, "SMTP")), res_ = Text.Combine(List.Transform(findSMTP_, each Text.Trim(Text.AfterDelimiter(_, "SMTP:"))), ", ") in res_Please accept the solution when done and consider giving a thumbs up if posts are helpful.
AlB
3 years agoHi shocktech
Please accept the solution when done and consider giving a thumbs up if posts are helpful. Contact me privately for support with any larger-scale BI needs, tutoring, etc. |
shocktech
Yes indeed. I am using PowerQuery in Excel 365 Desktop app. I should have clarified this. Apologies.
