ysherriff
Resolver II
3 years agoM Code to extract between characters that are not same position
Hi all, Does anyone know how to extract the year from this text string? I trired "Text Extraction" and "Delimiter" but it is not coming out the way I want. I want the year in one column but I am al...
- 3 years ago
Thank you but this solution works
List.RemoveNulls (
List.Transform (
Text.Split ( _[Campaign Name], "-" ),
each try Number.From ( _ ) otherwise null
){0}
3 years agoNot applicable
Hi ysherriff - you could try something like Text.Remove - PowerQuery M | Microsoft Learn or Text.Select - PowerQuery M | Microsoft Learn
Select = Text.Select( [Text] , {"0".."9"} )
Remove = Text.Remove( [Text] , {"a".."z", "A".."Z"})
- ysherriff3 years ago
Resolver II
List.RemoveNulls (
List.Transform (
){0}
