KR300's avatar
KR300
1 year ago
How to take Max String value based on Another Column which contains same values.
Hi Team, Here based on the Isssue Id column we need to fetch max value of Fixversion and remove Other records. Description: Issue ID - 2 is having multiple FixVersions ( SFP.R.11.7, SFP.R.11....
  • Chewdata's avatar
    1 year ago
    Hey!
    You can try an variation on this code. Som additional code may be needed to clean your data before.
    The code below code does the following:
    1. use a custom function to create a numeric combined value from main and sub version.
    2. Group the rows on issue to get the max
    3. Filter the rows so only the value that equals max will remain.
        Source = YOURDATA,
        filterEmpty = Table.SelectRows(Source, each [FixVersion] <> null and [FixVersion] <> ""),
        fn_VersionCombined = (vVersion as text) =>
            split = Text.Split(vVersion, "."),
            main = split{2},
            sub = split{3},
            outcome  = Number.From(Text.Combine({main, if Number.From(sub) <= 9 then "0" & sub else sub}))
            outcome,
        invoke_fnVersionCombined = Table.AddColumn(filterEmpty, "VersionCombined", each fn_VersionCombined([FixVersion]), Int64.Type),
        GroupRows = Table.Group(invoke_fnVersionCombined, {"Issue ID"}, {{"Max", each List.Max([VersionCombined]), type number}, {"Table", each _, type table [Issue ID=nullable number, FixVersion=nullable text, VersionCombined=number]}}),
        ExpandTable = Table.ExpandTableColumn(GroupRows, "Table", {"FixVersion", "VersionCombined"}, {"FixVersion", "VersionCombined"}),
        FilterRows = Table.SelectRows(ExpandTable, each ([VersionCombined] = [Max]))
        FilterRows
    Hopefully this is usefull, if so consider accepting it as a solution to help other users!
    Good luck!
  • ronrsnfld's avatar
    ronrsnfld
    1 year ago
    The code I supplied earlier seems to work with your new sample:
    Source
    Results
    By the way, if you want to change the name of the resultant column, merely edit the last line of code before the "in":
    Change:
    Table.ExpandRecordColumn(#"Grouped Rows", "Latest Version", {"FixVersion"})
    to something like:
    Table.ExpandRecordColumn(#"Grouped Rows", "Latest Version", {"FixVersion"},{"MaxVersion"})
    1 year ago
    Thanks for the solution KR300 , Chewdata , ThxAlot  and Ahmedx  offered, and i want to offer some more information for user to refer to.
    hello KR300 , you can refer to the follwing code in advanced editor in power query.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bdBLCsAgDATQu2QtwbEf9QJdF7sU73+NfrDUMtk+EoaZWgXi5Nh2LQpokuaqhJHiQIWviu435YemkSJTYjIe4R+b+XNhWpkiU2LKTFcwGwwLhhlFYVTA1yH38j/q5QeDVxgWyN7JYcz0N8rtq7cT", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Issue ID" = _t, FixVersion = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Issue ID", Int64.Type}, {"FixVersion", type text}}),
        #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Text.Select([FixVersion],{"0".."9"})),
        #"Changed Type1" = Table.TransformColumnTypes(#"Added Custom",{{"Custom", type number}}),
        #"Grouped Rows" = Table.Group(#"Changed Type1", {"Issue ID"}, {{"Max", each let a=List.Max([Custom])
    in List.Select([FixVersion],each Text.Contains(Text.Remove(_,"."),Text.From(a))){0}, type nullable text}})
        #"Grouped Rows"
    Ouptut
    Best Regards!
    Yolo Zhu
  • AlienSx's avatar
    1 year ago
        result = Table.Group(
            source_table,
            "Issue ID",
                "FixVersion", (x) => List.Max(
                    x[FixVersion],
                    null,
                    (w) => ((nums) => Number.From(nums{0}) * 1000 +
                        Number.From(nums{1})
                    )(List.LastN(Text.Split(w, "."), 2))
        result
