KR300's avatar
KR300
1 year ago
How to take Max String value based on Another Column which contains same values.
Hi Team,
Here based on the Isssue Id column we need to fetch max value of Fixversion and remove Other records.
Description: Issue ID - 2 is having multiple FixVersions ( SFP.R.11.7, SFP.R.11.8 & SFP.R.11.9 ), but i want to fetch only one record for each Issue ID with Max FixVersion like below
  • Hey!
    You can try an variation on this code. Som additional code may be needed to clean your data before.
    The code below code does the following:
    1. use a custom function to create a numeric combined value from main and sub version.
    2. Group the rows on issue to get the max
    3. Filter the rows so only the value that equals max will remain.
        Source = YOURDATA,
        filterEmpty = Table.SelectRows(Source, each [FixVersion] <> null and [FixVersion] <> ""),
        fn_VersionCombined = (vVersion as text) =>
            split = Text.Split(vVersion, "."),
            main = split{2},
            sub = split{3},
            outcome  = Number.From(Text.Combine({main, if Number.From(sub) <= 9 then "0" & sub else sub}))
            outcome,
        invoke_fnVersionCombined = Table.AddColumn(filterEmpty, "VersionCombined", each fn_VersionCombined([FixVersion]), Int64.Type),
        GroupRows = Table.Group(invoke_fnVersionCombined, {"Issue ID"}, {{"Max", each List.Max([VersionCombined]), type number}, {"Table", each _, type table [Issue ID=nullable number, FixVersion=nullable text, VersionCombined=number]}}),
        ExpandTable = Table.ExpandTableColumn(GroupRows, "Table", {"FixVersion", "VersionCombined"}, {"FixVersion", "VersionCombined"}),
        FilterRows = Table.SelectRows(ExpandTable, each ([VersionCombined] = [Max]))
        FilterRows
    Hopefully this is usefull, if so consider accepting it as a solution to help other users!
    Good luck!
  • The code I supplied earlier seems to work with your new sample:
    Source
    Results
    By the way, if you want to change the name of the resultant column, merely edit the last line of code before the "in":
    Change:
    Table.ExpandRecordColumn(#"Grouped Rows", "Latest Version", {"FixVersion"})
    to something like:
    Table.ExpandRecordColumn(#"Grouped Rows", "Latest Version", {"FixVersion"},{"MaxVersion"})
    1 year ago
    Thanks for the solution KR300 , Chewdata , ThxAlot  and Ahmedx  offered, and i want to offer some more information for user to refer to.
    hello KR300 , you can refer to the follwing code in advanced editor in power query.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bdBLCsAgDATQu2QtwbEf9QJdF7sU73+NfrDUMtk+EoaZWgXi5Nh2LQpokuaqhJHiQIWviu435YemkSJTYjIe4R+b+XNhWpkiU2LKTFcwGwwLhhlFYVTA1yH38j/q5QeDVxgWyN7JYcz0N8rtq7cT", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Issue ID" = _t, FixVersion = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Issue ID", Int64.Type}, {"FixVersion", type text}}),
        #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Text.Select([FixVersion],{"0".."9"})),
        #"Changed Type1" = Table.TransformColumnTypes(#"Added Custom",{{"Custom", type number}}),
        #"Grouped Rows" = Table.Group(#"Changed Type1", {"Issue ID"}, {{"Max", each let a=List.Max([Custom])
    in List.Select([FixVersion],each Text.Contains(Text.Remove(_,"."),Text.From(a))){0}, type nullable text}})
        #"Grouped Rows"
    Ouptut
    Best Regards!
    Yolo Zhu
  • let
        result = Table.Group(
            source_table,
            "Issue ID",
                "FixVersion", (x) => List.Max(
                    x[FixVersion],
                    null,
                    (w) => ((nums) => Number.From(nums{0}) * 1000 +
                        Number.From(nums{1})
                    )(List.LastN(Text.Split(w, "."), 2))
        result
    • Split the version into the letters and digits portion
    • Split the digits portion by the dot, then combine them to create a whole number
    • Group by Issue ID
    • Sort each group by letter and digits
    • Return the last value of each subgroup
        Source = Table.FromColumns({
            {1,2,2,2,3,3,3,3},
            {"SFP.R.11.8","SFP.R.11.7","SFP.R.11.8","SFP.R.11.9","SFP.R.11.7","SFP.R.11.8","SFP.R.11.9","SFP.R.11.10"}},
                    type table[Issue ID=Int64.Type, FixVersion=text]),
    //Split digit and letter parts
        #"Split" = Table.AddColumn(Source, "SplitParts", each
                split = Text.Split([FixVersion],"."),
                letter = Text.Combine(List.Range(split,0,2),"."),
                digits = Number.From(split{2})*1000 + Number.From(split{3})
                [letters=letter, digits=digits],
                type [letters=text, digits=Int64.Type]),
        #"Expanded SplitParts" = Table.ExpandRecordColumn(Split, "SplitParts", {"letters", "digits"}, {"letters", "digits"}),
        #"Grouped Rows" = Table.Group(#"Expanded SplitParts", {"Issue ID"}, {
            {"Latest Version", each Table.Last(Table.Sort(_, {{"letters", Order.Ascending}, {"digits", Order.Ascending}}))
            , type [Issue ID=number, FixVersion=text, letters=text, digits=number]}}),
        #"Expanded Latest Version" = Table.ExpandRecordColumn(#"Grouped Rows", "Latest Version", {"FixVersion"})
  • Chewdata's avatar
    Chewdata
    Icon for Responsive Resident rankResponsive Resident
    Hey!
        Source = YOURDATA,
            main = split{2},
            sub = split{3},
            outcome,
        FilterRows
    Good luck!
  • pls try this code
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUQp2C9AL0jM01LNQitWJVjJCFjLHFMKiyhIsZIyp0RhTozEBjYYGSrGxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Issue ID" = _t, FixVersion = _t]),
        #"Removed Duplicates" = Table.Distinct(#"Changed Type", {"FixVersion"}),
        #"Grouped Rows" = Table.Group(#"Removed Duplicates", {"Issue ID"}, {{"Count", each List.Max([FixVersion]), type nullable text}})
        #"Grouped Rows"
    • KR300's avatar
      KR300
      Hi it helps. But If we have some more data like in the screenshot. Pls have a look.
      1. I need more help on this & how it can be done.
      2. If Issue ID is same, I want only one Issue ID with Max FixVersion Record
      3. Note: FixVersion from Least to Highest ( 8.1,8.2,....,8.10,8.11, 8.12..,   11.1, 11.2,....,11.10, 11.11, 11.12.., )
      • Chewdata's avatar
        Chewdata
        Hey,
        Have you tried my solution yet? It should do just that. Same as the other solutions. Otherwise the problem you are facing is not yet clear to us.
    • ronrsnfld's avatar
      ronrsnfld
      With your algorithm, if I add  SFP.R.10.22 to ID3, it gets returned as the latest version vs SFP.R.11.10
  • KR300's avatar
    KR300
    I have entere some more data. How to do in this case
      ronrsnfld
      Source
      Results
      Change:
      to something like:
      • KR300's avatar
        KR300
        But Power BI Consider SFP.R.8.9 as max string Compared to SFP.R.11.8 ( but this is the newest version right and Max Stiring). See Key -> SMAR-2363
        #"Grouped Rows"
    Ouptut
    Best Regards!
    Yolo Zhu
  • let
            source_table,
            "Issue ID",
                    x[FixVersion],
                    null,
        result
  • KR300's avatar
    KR300
    Hi All, A lot of thanks for everyone. I will try what is the best way of workaround from all above options & Reply to all
