ClemFandango
Advocate II
3 years agoHow to join query based on two columns using Power Query
Hi there, PowerBI people! I have a query called “Market” that is merging a query (called “Sheet2”) using a left outer join. The code being used is shown below = Table.NestedJoin(#"Reordered Columns...
- 3 years ago
You put the columns in the same section as the existing join key { "field1", "field2"}.
If you use the interface to select the key columns, you select the first 2 columns then use 'shift' key and select more pairs of columns
HotChilli
3 years agoYou put the columns in the same section as the existing join key { "field1", "field2"}.
