Keith011
Helper III
4 years agoHow to aggregate values without using "Group By" function?
Hi there. Below is my table in Power Query How can I do a "Group By" Email and sum up the ActualtimeSpent (minutes) column? Without using Group By I tried using group by but its taking...
- 4 years ago
Hi Keith,
This may be a flaw in the code that I provided (hard to say without seens the entire code in your query). Sometimes the code structure causes PQ to run nested queries several times. The one that I've provided last would be more efficient from this perspective.
However, it may be easier to add the cumulative column as we go with the AtcualTimeSpent calcs:
let Tasks = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("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", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Email = _t, startedAt = _t, finishedAt = _t, #"timeSpent (minutes)" = _t]), #"Changed Type" = Table.TransformColumnTypes(Table.Combine({Tasks, Tasks, Tasks, Tasks, Tasks, Tasks, Tasks, Tasks, Tasks}),{{"Email", type text}, {"startedAt", type time}, {"finishedAt", type time}, {"timeSpent (minutes)", Int64.Type}}), Schedule = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMrIyMACiglylWJ1oJWMrYxgvFgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Task Duration" = _t]), ChangeType = Table.TransformColumnTypes(Schedule,{{"Task Duration", type time}}), processStarts = Time.From(ChangeType{0}[Task Duration]), processEnds = ChangeType{1}[Task Duration], #"Added latestStartedAt" = Table.AddColumn(#"Changed Type", "latestStartedAt", each List.Max({[startedAt],processStarts}), type time), #"Added earliestFinishedAt" = Table.AddColumn(#"Added latestStartedAt", "earliestFinishedAt", each List.Min({[finishedAt], processEnds}),type time), #"Filtered Rows" = Table.SelectRows(#"Added earliestFinishedAt", each [latestStartedAt] < [earliestFinishedAt]), fCalculate = (t as table) => let m = Table.Buffer(t), fProcess = (a, n)=> let previousFinishedAt = List.Last(a)[earliestFinishedAt], previousCumul = List.Last(a)[cumul], currentStartedAt = n[latestStartedAt], currentFinishedAt = n[earliestFinishedAt], actualFinish = List.Last(a)[actualFinish], actualStart = List.Max({actualFinish, currentStartedAt}), outputRecord = [#"ActualtimeSpent (minutes)" = List.Max({0, Duration.TotalMinutes(currentFinishedAt-actualStart)}), actualFinish = List.Max({actualFinish, currentFinishedAt}), cumul = previousCumul + #"ActualtimeSpent (minutes)"] in outputRecord, process = List.Skip(List.Accumulate(Table.ToRecords(m), {[actualFinish = m{0}[startedAt], #"finishedAt" = m{0}[startedAt], cumul = 0]}, (a, n)=> a & { n & fProcess(a, n) })) in process, Group = Table.Group(#"Filtered Rows", "Email", {{"Data", fCalculate}}), Expand = Table.FromRecords(List.Combine(Group[Data]), Value.Type(Table.AddColumn(Table.AddColumn(#"Changed Type", "ActualtimeSpent (minutes)", each null,type number), "cumul", each null, type number))), Output = Table.Combine({Expand, Table.RemoveColumns(Table.SelectRows(#"Added earliestFinishedAt", each not ([latestStartedAt] < [earliestFinishedAt])), {"latestStartedAt", "earliestFinishedAt"})}) in OutputKind regards,
John
