cool_333
3 years agoFrequent Visitor
Help with power query
Hi, guys need help with power query transformation below is the raw data that need the output as 2nd table. Thanks in advance. Raw data
Rickmaurinus
Helper V
3 years agoReally fun challenge! You can make smart use of Splitter.SplitByCharacterTransition in this scenario.
Here's the alternative approach:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8kstV4hKTVTSUXLMSykC0eb65vpGBkamQKalvpEhiG0JZBuZGgBJQyMQYW4AYhsDRWJ1opW8EgsS84B8p8SsxCzcBhiCDTA2QRhgaGSsFBsLAA==", BinaryEncoding.Base64), Compression.Deflate)), {"ProjectRef", "ModelDataSet", "ProjectStart", "ProjectEnd", "FacilitiesUnitRate", "FacilitiesQuantity", "ServiceUnitRate", "ServiceQuantity"}),
// Sample binary data used for testing. Use the following line instead to get data from the table in the real implementation.
// Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
ChangeTypes = Table.TransformColumnTypes(Source,{{"ProjectRef", type text}, {"ModelDataSet", type text}, {"ProjectStart", type date}, {"ProjectEnd", type date}, {"FacilitiesUnitRate", Int64.Type}, {"FacilitiesQuantity", Int64.Type}, {"ServiceUnitRate", Int64.Type}, {"ServiceQuantity", Int64.Type}}, "en-US" ),
Unpivot = Table.UnpivotOtherColumns(ChangeTypes, {"ProjectRef", "ModelDataSet", "ProjectStart", "ProjectEnd"}, "Attribute", "Value"),
SplitAttribute = Table.SplitColumn(Unpivot, "Attribute", Splitter.SplitTextByCharacterTransition({"a".."z"}, {"A".."Z"} ), {"Category", "Attribute"}),
Pivot = Table.Pivot(SplitAttribute, List.Distinct(SplitAttribute[Attribute]), "Attribute", "Value", List.Sum),
#"Sorted Rows" = Table.Sort(Pivot,{{"ModelDataSet", Order.Ascending}, {"Category", Order.Ascending}})
#"Sorted Rows"
Thanks for prepping the initial dataset smozgur
@ me in replies or I'll lose your thread
Master Power Query M? -> https://powerquery.how
Read in-depth articles? -> BI Gorilla
Youtube Channel: BI Gorilla
If this post helps, then please consider accepting it as the solution to help other members find it more quickly.
smozgur
3 years agoThanks for prepping the initial dataset smozgur
Testing your solution Rickmaurinus. Looks interesting.
Edit: No, it is not interesting, it is beautiful! Thanks for posting it!
