Marija_JC
1 year agoNew Member
Help with M code conditional column
Hello, I woluld like to create an coditional column based on the text values from another column. So, it should be like: if column B has value " x", then text in column A sholud start from 4th cha...
- 1 year ago
use the following formula
= if [ColumnB] = "x" then Text.Middle([ColumnA], 3) else if [ColumnB] = "y" then Text.BeforeDelimiter([ColumnA], "-") else if [ColumnB] = "z" then Text.BetweenDelimiters([ColumnA], "(", ")") else null
1 year agoNot applicable
Hi Marija_JC ,
Thanks MarkLaf for the clean and accurate solution your logic perfectly aligns with the expected output shared by OP.
Hey Marija_JC did you get a chance to look at the solution above? It seems to cover all your conditions for "X", "Y" and "Z"exactly as described and shown in your screenshot. Let us know if it works as expected on your end or if you ran into any edge cases happy to help further.
Akhil.
