isg's avatar
isg
11 months ago
Help with Implementing Reiteration for Conditional Replacement of Values through "Coupled" Columns
Hi everyone,
I have some data that I will need help from you Power Query experts to transform. The data looks like the below table (Data Input). Column Ax is matched with Column Bx, Ay with By, Az with Bz.. I want to remove anything that are in the A Columns when it matches perfectly with their counterpart in Column B.
I am thinking the iterative function / code should have the following logic:
1. If value in Column Ax = Column Bx, then replace the value with blank (see Data2 row input + output)
2. If they partially match, only the matching one is replaced with blank (see Data4 row input + output)
3. If they do not match, leave them all behind (see Data3 row input + output)
Data Input:
 Column AxColumn AyColumn AzColumn BxColumn ByColumn Bz
Data1Ax1Ay1 Ax1
Data2 Ay2Az2 Ay2Az2
Data3Ax3 Az3
Data4Ax4Ay4
By4
Az4 Ay4Bz4
Data5Ax5Ay5
By5
  Ay5
By5
Bz6
Data Output:
Data1 Ay1 Ax1
Data2    Ay2Az2
Data3Ax3 Az3
Data4Ax4By4Az4 Ay4Bz4
Data5Ax5   Ay5
By5
Bz6
Currently, I am replacing value for each column in separate steps, so I have 3 different steps for each columns:
= Table.ReplaceValue(Table,each [Column Bx],null,Replacer.ReplaceValue,{"Column Ax"})
= Table.ReplaceValue(PrevStep,each [Column By],null,Replacer.ReplaceValue,{"Column Ay"})
= Table.ReplaceValue(PrevStep2,each [Column Bz],null,Replacer.ReplaceValue,{"Column Az"})
Would it be possible for me to have it only in one step and reiterate through the columns? I am able to get the column headers name for both the A and B side of things, but not sure how I can reiterate dynamically for both sides at once (Ax & Bx, then Ay & By instead of Ax & By).
Hope I was clear at the explanation! Will edit the post again if I need to clarify anything.
  • let
        replacer = (text01, text02) => Text.Replace(text01 ?? "", text02 ?? "", ""),
        fxr = (lst) => (
            (data) => {lst{0}} & List.Transform(List.Zip(data), (x) => replacer(x{0}, x{1})) & data{1}
        )(List.Split(List.Skip(lst), (List.Count(lst) - 1) / 2)),
        Source = Excel.CurrentWorkbook(){[Name="Table4"]}[Content],
        ttl = Table.ToList(Source, fxr),
        result = #table(Value.Type(Source), ttl)
        result
  • let
        fxr = (lst) => (
        result
    • isg's avatar
      isg
      Hi AlienSx ,
      First of all - thank you so much for your input. Second of all - I apologize in advance because I'm not as M savvy as most people here are so I'd probably will need some hand holding to understand the code.
      While I attempted to implement your code, I realized that I did not mention in my original post that:
      1. I have other columns in the table aside from the A & B Columns in my actual table. I removed the other columns in the example table in my post so that it's much easier to explain.
      2. The "blanks" in my columns are actually "null"s
      I implemented your code and modified the "Source" line to the table, and it seems to work! However, several things that I was wondering:
      1. I had to remove the other columns so that the table only consists of the primary key (Data1, Data2, ...) and the coupled columns. I would have to re-merge the end result to the beginning of the table, would there be an easier way to do this?
      2. All the ones that are "null" in the table ended up being a blank field and not a "null". Is there a way that it would stay "null" instead of blank?
      Both of these I can definitely just implement as separate steps in the code, but wondering if we could modify the functions instead.
      Thanks again for your help and sorry for the late response!
      • AlienSx's avatar
        AlienSx
        hello, isg
        1. Other columns: you don't need to remove other columns. E.g. use Table.CombineColumnsToRecord to combine all other columns (including primary key) into single column, make sure that this new column goes first, apply table transformation and then expand that column using Table.ExpandRecordColumn.
        2. Modify replacer function so that it checks if text01 is null or text01 = text02 (result must be null), text02 is null (result must be text01) otherwise result must be Text.Replace(text01, text02, "")
  • Here's another method that seems to work a bit faster.
    It uses List.Accumulate to iterate the Table.ReplaceFunction to check each pair of columns.
    Note that I use List.RemoveMatchingItems function. As written, it will only remove if there is a "perfect" match, as you wrote. If you want to make the match case-insensitive, or include other imperfections,  you can include the optional  Equation Criteria.
    However, if your actual layout is different, and/or if you have other columns in your actual data that are not relevant to your problem. That algorithm will need to be changed.
    Please read the code comments, explore the applied steps, and ask if you don't understand something.
    //Change next line to reflect your actual data source
        Source =Table,
    /*Written to accomodate any number of columns, but assumes they are all type text
      If you have other columns in your real data that are of a different type, this
      will need modification*/
        #"Changed Type" = Table.TransformColumnTypes(Source,
            List.Transform(Table.ColumnNames(Source), each {_, type nullable text})),
    /*If your real data has more columns that are not to be checked
      this algorithm to get the column pairs will need to be changed*/
        #"Columns" = [a=List.Skip(Table.ColumnNames(Source)),
                      b=List.Split(a,List.Count(a)/2),
                      c=List.Zip(b)][c],
        #"Replace Matches" = List.Accumulate(
            #"Columns",
            #"Changed Type",
            (s,c)=> Table.ReplaceValue(
                        s,
                        each Record.Field(_,c{0}),
                        each Record.Field(_,c{1}),
                        (x,y,z) as nullable text=> [a=Text.Split(y,"#(lf)"),
                                   b=Text.Split(z,"#(lf)"),
                                   c=List.RemoveMatchingItems(a,b),
                                   d=Text.Combine(c,"#(lf)")][d],
                        {c{0}}
        #"Replace Matches"
     Original
    Results
    • v-aatheeque's avatar
      v-aatheeque
      Hi isg
      Have you had a chance to look through the responses shared earlier? If anything is still unclear, we’ll be happy to provide additional support.
        v-aatheeque
        Hi isg
        Following up to confirm if the earlier responses addressed your query. If not, please share your questions and we’ll assist further.
    • isg's avatar
      isg
      Hi ronrsnfld ,
      First of all - Thank you so much for your input! Apologies for the late response, it took me a little bit to understand how to implement your code in my file, as I am not that code savvy.
      The example data/table that I've put in the original post is a simplified version of the actual data. I have about 155 columns in my data that are not part of the "coupled columns" and 23 pair of the "coupled columns". All of the 23 pair "coupled columns" have text as their data type. The rest of the 155 columns are either Int64.Type, text, date, or number. The primary key of the table is an Int64.Type.
      Additionally, the "coupled columns" are actually in two separate tables, but we can easily merge them as they use the same primary key. I merged them through left join, so there will be cases like Data3, where Table A (with columns Ax, Ay, and Az) do not have an accompanying pair in Table B (columns Bx, By, and Bz).
      I've modified your code to take the above facts into account:
      Source = Table.NestedJoin(TableA, {"PrimaryKey"}, TableB, {"PrimaryKey"}, "TableB", JoinKind.LeftOuter),
      Expand = Table.ExpandTableColumn(Source, "BColumns", TableBHeaders),
      FinalSource = Table.SelectColumns(Expand, //List of Relevant Columns),
      Columns = List.Zip({TableAHeaders, TableBHeaders}),
      Columns,
      FinalSource,
      s,
      {c{0}}
      #"Replace Matches"
      Your approach is what I had in mind when I first encountered this problem. I had figured out how to list.zip the headers but was not competent enough to understand how to use List.Accumulate and to build my own replacement function. I tried removing your change type step and the code seems to be working just fine without that step, but let me know of any edge cases I need to be aware of - so that I understand why we need to keep that step.
      The only part that I can't figure out when modifying your code is which line I need to modify when I want the blanks to come up as "null" instead of blanks. As I wrote in the other comment, I can certainly do another step where I null all the blanks, but wondering if I can just write it in the same step instead.
      Appreciate any help moving forward!
      • ronrsnfld's avatar
        ronrsnfld
        In general, Power Query works better if it knows the data types it is working on. But I don't believe that removing the #"Changed Type" step in my code will cause any problems. If you have many, many rows in your data, you could check to see if explicitly setting just the coupled columns to type text before the #"Replace Matches" steps makes a difference in execution time. I suspect it will not.
        And yes, with a more complex replacement line in the #"Replace Matches" step you could wind up with nulls instead of blanks in the replaced items. But I don't have time this morning to look at it further. And I don't know which method would be more efficient (replace in that step or replace all the blanks with nulls as a final step). I'll take a look at it later.
  • Here is a bit of a mismash of AlienSx's solution and ronrsnfld's solution. Table.ToList converts each row to a list and applies the function supplied in second arg, similar to AlienSx. In the function we are splitting text, removing from A matching in B, then re-combining, similar to ronrsnfld. And buffering and iterating through each row's list is relatively faster, although it probably won't be noticable unless you are dealing with non-small data (100k+ rows in my testing).
        fix_func = (row as list, optional row_headers as number) as list =>  [
            row_b = List.Buffer( row ),
            row_header_count = row_headers ?? 1,
            row_data_setSize = (List.Count(row_b)-row_header_count)/2, // assume two data column sets of equal length
            row_header = List.FirstN( row_b, row_header_count ),
            row_data_setB = List.LastN( row_b, row_data_setSize ),
            row_data_setA_removeB = List.Generate(
                ()=>0, each _ < row_data_setSize, each _ + 1,
                each [
                    item_a = row_b{row_header_count+_},
                    item_b = row_b{row_header_count+row_data_setSize+_},
                    removematch =
                        if item_a = null or item_b = null
                        then item_a
                        else Text.Combine(
                                Text.Split( item_a,"#(lf)" ),
                                Text.Split( item_b,"#(lf)" )
                            "#(lf)"
                ] [removematch]
            row_output = row_header & row_data_setA_removeB & row_data_setB
        ] [row_output],
        Source = Sample,
        FixRows = Table.ToList(Source, fix_func ),
        ToTable = Table.FromRows( FixRows, Value.Type(Source) )
        ToTable
    To test, I used your same sample data, but I also added in the following row to validate case where lines of A are a proper subset of lines of B.
    Added row in sample
    (blank) Column Ax Column Ay Column Az Column Bx Column By Column Bz
    Data6 Ax6     Ax6
    Bx6
    Target output (I'm assuming)
    Data6       Ax6
    Bx6
    Here is the output with the sample and code
    edit: updated row_data_setA_removeB step in fix_func to handle nulls
