mathias1998
3 years agoFrequent Visitor
Help with If function and matching between two columns
Hi, I have two existing columns (Column1 and Column2), and I would like to create a new custom column in Power Query which returns: -1 if Column1 and Column2 have the same values 0 if Column...
KT_Bsmart2gethe
Impactful Individual
3 years agomathias1998
Thank you. But what about the following. How can that be done?
Return the Total count of non-blank rows from Column2 (essentially if the COUNTA founction in DAX) if Column1 contains 01.09.2022
- KT_Bsmart2gethe3 years ago
