martinblom's avatar
martinblom
3 years ago
HELP Power Query Code - Formula for finding a text in a grouped column without expanding
Hello everyone,   I need your help to solve a problem.   This is my data: Step 1: Grouped Rows by PersonID   Step 2: Add Custom Column with the code: Table.Transpose(Table....
  • v-yanjiang-msft's avatar
    3 years ago
    Hi martinblom ,
    According to your description, here's my solution.
    Add a custom column.
    if List.Contains([Antal][Betalingskanal],"MOBILEPAY") then "True" else "False"
    I modify the sample to:
    And get the correct result:
    The whole M syatax is:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("lZC7CsJAEEX/ZetI5s5rd0oDEYKKgpWEFJaC/n/r2okGSbo5cA5cZhyTUpYCkGtqkmYJeCHOFY6nbjj05+213kzMLahFpKn5ioKMQyHZK3SXRba5vaHfPG/3x6JC2K3Cbtj/6uYKFrcSHzqwTuc/e2YLXV2IzX1oegE=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [PersonID = _t, AccountID = _t, Betalingskanal = _t, DWCreatedDate = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"PersonID", Int64.Type}, {"AccountID", Int64.Type}, {"Betalingskanal", type text}, {"DWCreatedDate", type date}}),
        #"Grouped Rows" = Table.Group(#"Changed Type", {"PersonID"}, {{"Antal", each _, type table [PersonID=nullable number, AccountID=nullable number, Betalingskanal=nullable text, DWCreatedDate=nullable date]}}),
        #"Added Custom" = Table.AddColumn(#"Grouped Rows", "Custom", each if List.Contains([Antal][Betalingskanal],"MOBILEPAY") then "True" else "False")
        #"Added Custom"
    I attach my sample below for your reference.
    Community Support Team _ kalyj
    If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
