Help on Power BI Integration features
HI,
I would like to know below option is available or not.
1. Is it possible to integrate Power BI reports with Web application?
2. Is it possible to integrate Power BI reports with native mobile App (calling power bi report from another app)?
3. Is it possible to integrate dashDB for Power BI reports.
SM
- Anonymous9 years ago
Hi Sandeep,
Firstly, you are able to integrate Power BI reports with Web application by using Power BI API, for more details, please review this article: Integrate a report into an app.
Secondly, Microsoft provides Power BI mobile apps to view Power BI reports, you are able to see reports directly in iOS, Android and Windows apps, you can get more details in this article: Power BI apps for mobile devices.
Thirdly, do you want to connect to IBM dashDB from Power BI and create reports? If that is the case, you can create a ODBC data source for IBM dashDB following the instructions in this article, then connect to the ODBC data source from Power BI Desktop. This way, you are able to create reports using data in IBM dashDB and publish the reports into Power BI Service.
Lydia Zhang - Anonymous9 years ago
Hi Sandeep,
Based on the following sources, you are able to integrate Power BI report into mobile applications.
Bring the Power into Your Application; Power BI Embedded
PowerBI-CSharp
Lydia Zhang
- Sandeep
Dear Team,
SM
- AnonymousNot applicable
Hi Sandeep,
Lydia Zhang- Sandeep
Thanks Anonymous for response.
1. Is this possible to integrate Power BI reports to customer native mobile app.
(this is one of the requirement)
SM
