6 years agoNot applicable
Help creating dynamic parameters for power query
Hi all, Need help in creating a dynamic parameter to my query in power bi query as below: (dtquery as text) => let url="https://<instance>.xxx.com/api/now/table/incident?sysparm_display_value=tr...
Mariusz
6 years agoHi Anonymous
So there is a clear indication that the below part is wrong.
[Query=sysparm_query&"="&sys_created_on&STARTSWITH&dtquery]
most probably you have not defined sysparm_query anywrer in power query.
Mariusz
If this post helps, then please consider Accepting it as the solution.
Please feel free to connect with me.
LinkedIn
Mariusz
Mariusz Thanks for your reply, But if you see my URL I am actually using the parameter in the query:
url="https://<instance>.xxx.com/api/now/table/incident?sysparm_display_value=true&sysparm_exclude_reference_link=true&sysparm_limit=1&sysparm_query=sys_created_onSTARTSWITH2020-07-08",
Source = Json.Document(Web.Contents(url,[Query=sysparm_query&"="&sys_created_on&STARTSWITH&dtquery]))
