Anonymous's avatar
7 years ago
Excel - Power Query: VBA for looping through slicers created using data model. Help!
All - this is in RE: Excel VBA. I am looking for looping through slicer selection and print PDF's. my code does work for standard pivots, but it does not work when using it on PowerPivot which is what I am looking for.
Can anyone please shed some light on how to turn the below so it works in powerpivot? (slicer from power pivot source data)
Let me know any questions - looking forward to hearing any tips :) :)
Thanks! :)
Option Explicit
Sub ExportPDFs()
Dim sI As SlicerItem, sI2 As SlicerItem, sc As SlicerCacheDim fname$
Set sc = ActiveWorkbook.SlicerCaches("Slicer_Date")
With sc
    For Each sI In sc.SlicerItems
        If sI.HasData = True Then        sc.ClearManualFilter
        For Each sI2 In sc.SlicerItems
            If sI.Name = sI2.Name Then sI2.Selected = True Else: sI2.Selected = False
        Next        Debug.Print sI.Name
        fname = sI.Caption & " " & Format(Date, "MM-DD-YYYY") & " " & "Report"        ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:=fname, _
        Quality:=xlQualityStandard, IncludeDocProperties:=True, IgnorePrintAreas:=False, OpenAfterPublish:=False
        End If
    Next    ActiveWorkbook.SlicerCaches("Slicer_Year").ClearManualFilter
    MsgBox "Reports Saved"
End With
End Sub
1 Reply
  • v-juanli-msft's avatar
    v-juanli-msft
    Hi Anonymous
    As tested, i'm afriad it doesn't support to loop slicer and export to pdf programmatically currently.
    There is a custom visual which works like a dynamic slicer and animates your other power bi visuals without any user interaction.
    http://blog.pragmaticworks.com/power-bi-custom-visuals-play-axis
    Maggie
