Dynamically skip or delete rows between specific values in power query
- 1 year ago
Hello Data_Stylist,
Here is a possible solution:let Source = #table( type table [Source.Name = text, Name = text, #"PRODUCT_COST($/L)" = text], { {"A.xlsx", "Jan", "2.42"}, {"A.xlsx", "Jan", "5.87"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "Total:"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "2.44"}, {"A.xlsx", "Feb", "5.26"}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Total:"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "5.12"}, {"A.xlsx", "Feb", "5.87"}, {"A.xlsx", "Feb", "4.47"}, {"A.xlsx", "Feb", "7.92"} }), ListMaches = let findMatches = (t) => List.PositionOf(Source[#"PRODUCT_COST($/L)"], t, Occurrence.All) in List.Zip({findMatches("Total:"), findMatches("Product Cost $/litre")}), RemoveRows = List.Accumulate(List.Reverse(ListMaches), Source, (s, c)=> Table.RemoveRows(s, c{0}, c{1} - c{0} + 1)) in RemoveRows - 1 year ago
I figured out the rest
Thanks mromain The solution worked for the sample data I provided, but when applied to the actual data which contains thousands of row, I got the range error below.
the first step (ListMaches) of extracting list that matched the appropriate conditions worked well, the extraction step is where there seems to be an issue. Any fix?
Expression.Error: The 'count' argument is out of range.
Details:
-5
- v-venuppu1 year ago
Hi Data_Stylist ,
Thank you KNP mromain for the prompt response.
I want to check whether you are able to resolve the issue..?If so, please mark the helpful reply and accept it as the solution. This will be helpful for other community members who have similar problems to solve it faster.
