Dynamically skip or delete rows between specific values in power query
- 1 year ago
Hello Data_Stylist,
Here is a possible solution:let Source = #table( type table [Source.Name = text, Name = text, #"PRODUCT_COST($/L)" = text], { {"A.xlsx", "Jan", "2.42"}, {"A.xlsx", "Jan", "5.87"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "Total:"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "2.44"}, {"A.xlsx", "Feb", "5.26"}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Total:"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "5.12"}, {"A.xlsx", "Feb", "5.87"}, {"A.xlsx", "Feb", "4.47"}, {"A.xlsx", "Feb", "7.92"} }), ListMaches = let findMatches = (t) => List.PositionOf(Source[#"PRODUCT_COST($/L)"], t, Occurrence.All) in List.Zip({findMatches("Total:"), findMatches("Product Cost $/litre")}), RemoveRows = List.Accumulate(List.Reverse(ListMaches), Source, (s, c)=> Table.RemoveRows(s, c{0}, c{1} - c{0} + 1)) in RemoveRows - 1 year ago
I figured out the rest
I don't know what other columns you may have but could you filter out 'Total:' and 'Product Cost $/litre' and then group? See code below.
Source =
Table.FromRows(
Json.Document(
Binary.Decompress(
Binary.FromText(
"i45WctSryCmuUNJR8krMA5JGeiZGSrE6GOKmehbm2MQN9UxMqCGeV5qTQw31IfkliTlWpOgY/OJuqUlAMqAoP6U0uUTBOb+4REFFPyezpCgVmzpc+g31TElRboQR8BBxUz0jMyoYT1vl2FIBfh20CnVTPUMj7OLo+QkibqJnglXcXM8SaE4sAA=="
, BinaryEncoding.Base64
, Compression.Deflate
, let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [SourceName = _t, Name = _t, PRODUCT_COST_per_L = _t]
, ChangeType =
Table.TransformColumnTypes(
Source
{ "SourceName", type text }
, { "Name", type text }
, { "PRODUCT_COST_per_L", type text }
, FilterRows =
Table.SelectRows(
ChangeType
, each (
[PRODUCT_COST_per_L] <> "Product Cost $/litre"
and [PRODUCT_COST_per_L] <> "Total:"
, ChangeType1 =
FilterRows
{ "PRODUCT_COST_per_L", type number }
, GroupRows =
Table.Group(
ChangeType1
, { "SourceName", "Name" }
{ "Count", each List.Sum([PRODUCT_COST_per_L]), type nullable text }
GroupRows
Thanks KNP Unfortunately the solution took out the data I need as well (see screenshot below). I only need to remove rows from "Total:" and "Product Cost $/litre" while keeping everything else.
Your solution
Desired Solution
- KNP1 year ago
Yeah, I wasn't sure if this was the complete data or just what you're able to share.
I thought you may have other columns to group on to allow you to keep the individual rows.
At any point in the process, do you have more/other columns available that could be used for filtering?
- Data_Stylist1 year agoNew Member
No, I've explored the other filter options and none would work perfectly. The best solution would be to conditionally delete based on values in PRODUCT_COST_PER_L column.
