Dynamically skip or delete rows between specific values in power query
- 1 year ago
Hello Data_Stylist,
Here is a possible solution:let Source = #table( type table [Source.Name = text, Name = text, #"PRODUCT_COST($/L)" = text], { {"A.xlsx", "Jan", "2.42"}, {"A.xlsx", "Jan", "5.87"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "Total:"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "2.44"}, {"A.xlsx", "Feb", "5.26"}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Total:"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "5.12"}, {"A.xlsx", "Feb", "5.87"}, {"A.xlsx", "Feb", "4.47"}, {"A.xlsx", "Feb", "7.92"} }), ListMaches = let findMatches = (t) => List.PositionOf(Source[#"PRODUCT_COST($/L)"], t, Occurrence.All) in List.Zip({findMatches("Total:"), findMatches("Product Cost $/litre")}), RemoveRows = List.Accumulate(List.Reverse(ListMaches), Source, (s, c)=> Table.RemoveRows(s, c{0}, c{1} - c{0} + 1)) in RemoveRows - 1 year ago
I figured out the rest
Hello Data_Stylist,
Source = #table(
RemoveRows- Data_Stylist1 year agoNew Member
Thanks mromain The solution worked for the sample data I provided, but when applied to the actual data which contains thousands of row, I got the range error below.
the first step (ListMaches) of extracting list that matched the appropriate conditions worked well, the extraction step is where there seems to be an issue. Any fix?
Expression.Error: The 'count' argument is out of range.
Details:
-5- Data_Stylist1 year agoNew Member
- v-venuppu1 year ago
Hi Data_Stylist ,
Thank you KNP mromain for the prompt response.
I want to check whether you are able to resolve the issue..?If so, please mark the helpful reply and accept it as the solution. This will be helpful for other community members who have similar problems to solve it faster.
- mromain1 year agoRegular Visitor
It's hard to answer without knowing your source data.
However, I can reproduce the error with this dataset where “Total:” is after “Product Cost $/liter” for the second occurrence.
Maybe it's the same problem with your source data.let Source = #table( type table [Source.Name = text, Name = text, #"PRODUCT_COST($/L)" = text], { {"A.xlsx", "Jan", "2.42"}, {"A.xlsx", "Jan", "5.87"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "1.44"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", "Total:"}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Jan", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "2.44"}, {"A.xlsx", "Feb", "5.26"}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "1.5"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Product Cost $/litre"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "Total:"}, {"A.xlsx", "Feb", null}, {"A.xlsx", "Feb", "5.12"}, {"A.xlsx", "Feb", "5.87"}, {"A.xlsx", "Feb", "4.47"}, {"A.xlsx", "Feb", "7.92"} }), ListMaches = let findMatches = (t) => List.PositionOf(Source[#"PRODUCT_COST($/L)"], t, Occurrence.All) in List.Zip({findMatches("Total:"), findMatches("Product Cost $/litre")}), RemoveRows = List.Accumulate(List.Reverse(ListMaches), Source, (s, c)=> Table.RemoveRows(s, c{0}, c{1} - c{0} + 1)) in RemoveRows
