sruthicb
3 years agoFrequent Visitor
Data load using ODBC Connection-Hive DB
I'm using ODBC connection to connect to Hive database and using below simple query to query the database. select col1,col2,col3 from table; when the data is loaded in the preview in the he...
- 3 years ago
Hi sruthicb
I don't have a Hive database to do a test, but maybe you can give a new name for every column in the SQL statement with "AS". For example,
select col1 as 'col1', col2 as 'col2', col3 as 'col3' from table;Best Regards,
Community Support Team _ Jing
v-jingzhang
3 years agoHi sruthicb
select
col1 as 'col1',
col2 as 'col2',
col3 as 'col3'
from table;
