Krishna09's avatar
Krishna09
3 years ago
Data flow data importing issue and dataflow stops at navigation step
Hello All, I have imported a csv file data from sharepoint folder to dataverse table two days back using dataflow in dataverse. it was succesfull. but if I see the data flow now, it show invalid cre...
    3 years ago
    Hi Krishna09 ,
    There is an same issue and the issue has been submitted to ICM (338416793) . I'll be back with an update if there's any progress .
    Gao
    Community Support Team
    If there is any post helps, then please consider Accept it as the solution  to help the other members find it more quickly. If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
    How to get your questions answered quickly -- How to provide sample data
