MrMP
4 years agoHelper III
data flow csv from sharepoint folder doesnt work (encoding problem?)
Hi all,
I am trying to combine dozens of csv files that are stored on sharepoint folder using data flow. I did try it with Power Query and it worked nicely. Now with data flows I am getting weird characters and I have no idea why. csv is encoded in UTF-8.
Please see the screenshot below:
Thank you for your help!
I have changed the query completely now and tried combining it differently. Now everything works.
- KNPSuper User
Are you able to post your full Power Query code?
(mask any sensitive detail)
- MrMPHelper III
- lbendlinSuper User
This is a ZIP file, not a CSV.
- MrMPHelper III
That folder contains only csv, there are no zip files there.
