Custom Column in Power query, Returns column values from different rows with same column ID
Hello Guys!
I need to create a custom column that combines all the "ITEM" with the same "ID".
Hi kladkent ,
Try this example query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXJydFeK1YGwfRwDQvwDwFwjINfVMSjAw9/PFS4Q4Orn7OmD4MIljYE8b9dIJ3/HIBe4gLOHo2eQUmwsAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, ITEM = _t]), groupRows = Table.Group(Source, {"ID"}, {{"data", each _, type table [ID=nullable text, ITEM=nullable text]}, {"CUSTOM COLUMN", each Text.Combine([ITEM], ", "), type nullable text}}), expandDataCol = Table.ExpandTableColumn(groupRows, "data", {"ITEM"}, {"ITEM"}) in expandDataColYou basically group your table on [ID] and add an 'All Rows' aggregated column and a 'SUM' column on [ITEM].
This obviously gives an error, so you adjust your Group By code to change List.Sum([ITEM]) to Text.Combine([ITEM], ", ").
You then expand the [ITEM] column back out from the nested All Rows column.
Example output:
Pete
- BA_Pete
Hi kladkent ,
Example output:
Pete
- BA_Pete
You're welcome.
Don't forget to give a thumbs-up on any posts that have helped you 👍
Pete
