Connect to Jira with Power BI - code for a function
- 1 year ago
I've made an updated version of the funciton that uses the v3 API (the old one is deprecated). Also runs a bit quicker.
Instructions on how to use this function:
- Copy the code below into a blank query in Power BI (using the advanced editor).
- Update the 'jiraDomain' variable using advanced editor (near the top of the code) with the domain you see when you login to your Jira.
- Generate and save an access token as per Manage API tokens for your Atlassian account | Atlassian Support.
- Invoke the function:
- Put the email address you use to login to Jira in the 'jiraUsername'.
- Put the token from step 3. above into the 'jiraAccessToken'.
- Put a comma demilted list of the fields you want to return in the 'fields' parameter e.g. 'summary, parent, status':
- This list is not case sensitive.
- You can enter custom field names here.
- If you have more than 1 custom field with the same name it will return both fields with the custom field id added as a suffix.
- Add a JQL statement that specifies the issues you want to return.
- If you want to return everything you can enter 'key IS NOT EMPTY'.
let Source = (jiraUsername as text, jiraAccessToken as text, fields as text, jql as text) => let //test data // jiraUsername = jiraUser, // jiraAccessToken = jiraToken, // fields = "id, parent, summary", // jql = "project = kan", //!!!UPDATE THE BELOW VARIABLE!!! jiraDomain = "https://<your-domain>.atlassian.net", //authenication auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), //convert_field_names_to_ids function convert_field_names_to_ids = (jiraUsername as text, jiraAccessToken as text, fields as text) => let fieldsConverted = if fields = "id" then "key" else Text.Replace(Text.Replace(fields," ,",","),", ",","), fieldsToGetAsList = Text.Split(Text.Lower(fieldsConverted),","), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), addGetFieldCheck = Table.AddColumn(expandFieldRecords, "getField?", each List.Contains(fieldsToGetAsList,Text.Lower([name]))), filterToFieldsToGet = Table.SelectRows(addGetFieldCheck, each ([#"getField?"] = true)), createFieldsString = Text.Combine(Table.Column(filterToFieldsToGet,"id"),",") in createFieldsString, //get_jira_fields_with_rename_lists get_jira_fields_with_rename_lists = (jiraUsername as text, jiraAccessToken as text)=> let auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), #"Added Custom" = Table.AddColumn(expandFieldRecords, "renameList", each if List.Count(let name = [name] in Table.Column(Table.SelectRows(expandFieldRecords, each ([name] = name)),"name"))>1 then {[id],[name] & " (" & [id] & ")"} else {[id],[name]}) in #"Added Custom", //field variables fields_list = Text.Lower(Text.Replace(Text.Replace(fields," ,",","),", ",",")), id_or_key_request = fields_list = "id" or fields_list = "key" or fields_list = "id,key" or fields_list = "key,id", fields_for_query = if fields = null or id_or_key_request then {"key"} else List.RemoveItems(Text.Split(convert_field_names_to_ids(jiraUsername, jiraAccessToken, fields_list), ","), {"issuekey"}), get_issues_list_function = (optional next_page_token as text) => Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search/jql", [ Headers = [ Authorization="Basic " & auth, #"Content-Type" = "application/json" ], Content = Json.FromValue( [ jql = jql, maxResults = 5000, fields = fields_for_query, nextPageToken = next_page_token ] ) ] )), get_issues = List.Generate( () => get_issues_list_function(), each Record.HasFields(_, "issues"), each try get_issues_list_function(_[nextPageToken]) otherwise [] ), #"Converted to Table" = Table.FromList(get_issues, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"issues"}, {"issues"}), #"Expanded issues" = Table.ExpandListColumn(#"Expanded Column1", "issues"), #"Expanded issues 1" = Table.ExpandRecordColumn(#"Expanded issues", "issues", {"id", "key", "fields"}, {"id", "key", "fields"}), #"Expanded fields" = if id_or_key_request then #"Expanded issues 1" else Table.ExpandRecordColumn(#"Expanded issues 1", "fields", fields_for_query), rename_list = Table.SelectRows(get_jira_fields_with_rename_lists(jiraUser, jiraToken), each List.Contains(fields_for_query, [key]))[renameList], #"Renamed columns" = Table.RenameColumns(#"Expanded fields", rename_list) in #"Renamed columns" in Source
//test data
//authenication
createFieldsString,
#"Added Custom",
//field variables
Headers = [
jql = jql,
maxResults = 5000,
get_issues =
List.Generate(
#"Renamed columns"
Source- svvelinov1 year agoNew Member
Hey DanMcG,
Thanks so much for your detailed guidance on connecting Jira to Power BI — everything works like a charm in Power BI Desktop!
The only issue I’m still stuck on is when I publish the report to the Power BI Service. During scheduled or manual refresh, I get the following error:
Web.Contents failed to get contents from rest/api/3/search/jql
Interestingly, the connection to the other Jira endpoint — rest/api/3/field — works perfectly and authenticates without issue.
Do you know what I need to adjust so that both connections authenticate successfully in the Power BI Service?
Thanks in advance for your help!
- TomJerry1 year agoNew Member
Did you figure this one out? I'm stuck at the same point as you...
