complex power query transformation help
- 1 year ago
Hi rob_vander2 Could you try this please After Loading the data to Power Query
Sort the Data:
Sort the table by ID, Category, Sub Category, Type, and Month in ascending order.
Create a Custom Column for Rolling Total:
- Go to Add Column > Custom Column:List.Sum(
Table.SelectRows(
#"Previous Step",
(x) =>
x[ID] = [ID] and
x[Category] = [Category] and
x[Sub Category] = [Sub Category] and
x[Type] = [Type] and
Date.FromText(x[Month]) <= Date.FromText([Month]) and
Date.FromText(x[Month]) >= Date.AddMonths(Date.FromText([Month]), -2)
)[Value]
)Rename the custom columnIf this post helped please do give a kudos and accept this as a solution
Thanks In Advance
- 1 year ago
I don't know, you have to test it 😉
You can also try this one (I've just added one 0 as 4th argument of inner Table.Group), but you can notice the speed difference. This will work if your data is sturcutred as your sample.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXJ0BBFAHALiBacW6BqZABmGBgZKsTrYlPgnl0CUmKKpcAKpMAISfvllOAyBK3FJTYYosYSoUAAyMTF2B5DhRiPCbsRUQn03OiEbj9ONcENwuxGuBMWNsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Category = _t, #"Sub Category" = _t, Type = _t, Month = _t, Value = _t]), // You can delete this step when applying on real data. ReplacedBlanks = Table.TransformColumns(Source, {}, each if Text.Trim(_) = "" then null else _), ChangedType = Table.TransformColumnTypes(ReplacedBlanks,{{"Value", Int64.Type}}), TransformedValue = Table.Combine(Table.Group(ChangedType, "ID", {{"T", each Table.Combine(Table.Group(_, {"ID", "Category", "Sub Category", "Type"}, {{"T2", (x)=> if x{0}[ID] = null then x else let a = Table.ToRecords(x) in Table.FromRecords(List.RemoveLastN(a, 1) & {List.Last(a) & [Value = List.Sum(x[Value])]}) , type table}}, 0)[T2]), type table}}, 0, (x,y)=> Byte.From(y is null))[T]) in TransformedValue
dufoq3 Could you please explain how TransformedValue step works?
TransformedValue step explanation in steps:
- Group rows by "ID"
- Inner group rows by columns: "ID", "Category", "Sub Category", "Type"
- Replace last [Value] with sum of [Value] column (for this inner group step)
- Combine Inner group to 1 table
- Combine Outer group to 1 table
- rob_vander21 year ago
Helper II
dufoq3 How performant it will be? I have millions of data.
- dufoq31 year ago
