rob_vander2's avatar
rob_vander2
1 year ago
complex power query transformation help
Hi All,   I have below dataset and required output as attached. I need to rolling quarterly  figure for Value for each combination of ID,Category,Sub Category and Type. For example, for Month Dec-2...
  • Akash_Varuna's avatar
    1 year ago
    Hi rob_vander2 Could you try this please  After Loading the data to Power Query
    • Sort the Data:
      • Sort the table by ID, Category, Sub Category, Type, and Month in ascending order.
    • Create a Custom Column for Rolling Total:
      • Go to Add Column > Custom Column:
        List.Sum(
        Table.SelectRows(
        #"Previous Step",
        (x) =>
        x[ID] = [ID] and
        x[Category] = [Category] and
        x[Sub Category] = [Sub Category] and
        x[Type] = [Type] and
        Date.FromText(x[Month]) <= Date.FromText([Month]) and
        Date.FromText(x[Month]) >= Date.AddMonths(Date.FromText([Month]), -2)
        )[Value]
        Rename the custom column
        If this post helped please do give a kudos and accept this as a solution
        Thanks In Advance
  • dufoq3's avatar
    dufoq3
    1 year ago
    I don't know, you have to test it 😉
    You can also try this one (I've just added one 0 as 4th argument of inner Table.Group), but you can notice the speed difference. This will work if your data is sturcutred as your sample.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXJ0BBFAHALiBacW6BqZABmGBgZKsTrYlPgnl0CUmKKpcAKpMAISfvllOAyBK3FJTYYosYSoUAAyMTF2B5DhRiPCbsRUQn03OiEbj9ONcENwuxGuBMWNsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Category = _t, #"Sub Category" = _t, Type = _t, Month = _t, Value = _t]),
        // You can delete this step when applying on real data.
        ReplacedBlanks = Table.TransformColumns(Source, {}, each if Text.Trim(_) = "" then null else _),
        ChangedType = Table.TransformColumnTypes(ReplacedBlanks,{{"Value", Int64.Type}}),
        TransformedValue = Table.Combine(Table.Group(ChangedType, "ID", {{"T", each Table.Combine(Table.Group(_, {"ID", "Category", "Sub Category", "Type"}, {{"T2", (x)=> if x{0}[ID] = null then x else let a = Table.ToRecords(x) in Table.FromRecords(List.RemoveLastN(a, 1) & {List.Last(a) & [Value = List.Sum(x[Value])]}) , type table}}, 0)[T2]), type table}}, 0, (x,y)=> Byte.From(y is null))[T])
        TransformedValue
