wingsted93
5 years agoFrequent Visitor
comparing rows values for conditional column in power query
I have data like follows: The 'EndDatePopulated' is the column that im trying to create in power query using M. I want the EndDate if it is present. If it is not present it is either because t...
- 5 years ago
Hi wingsted93 ,
Besides using power query like @ Rocco_sprmnt21 mentioned, you can also using DAX to create a calculated column to achieve this:
EndDatePopulated = VAR _count = CALCULATE ( COUNT ( 'Table'[ID] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ) RETURN IF ( _count >= 2, SWITCH ( TRUE (), [StartDate] = CALCULATE ( MIN ( 'Table'[StartDate] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ), CALCULATE ( MAX ( 'Table'[StartDate] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ) - 1, DATE ( 9999, 1, 1 ) ), SWITCH ( TRUE (), ISBLANK ( 'Table'[EndDate] ), DATE ( 9999, 1, 1 ), 'Table'[EndDate] ) )Best Regards,
v-yingjl
5 years agoHi wingsted93 ,
EndDatePopulated =
VAR _count =
IF (
_count >= 2,
SWITCH (
TRUE (),
[StartDate]
= CALCULATE (
) - 1,
DATE ( 9999, 1, 1 )
SWITCH (
TRUE (),
'Table'[EndDate]
