comparing rows values for conditional column in power query
- 5 years ago
Hi wingsted93 ,
Besides using power query like @ Rocco_sprmnt21 mentioned, you can also using DAX to create a calculated column to achieve this:
EndDatePopulated = VAR _count = CALCULATE ( COUNT ( 'Table'[ID] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ) RETURN IF ( _count >= 2, SWITCH ( TRUE (), [StartDate] = CALCULATE ( MIN ( 'Table'[StartDate] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ), CALCULATE ( MAX ( 'Table'[StartDate] ), FILTER ( ALL ( 'Table' ), 'Table'[ID] = EARLIER ( 'Table'[ID] ) ) ) - 1, DATE ( 9999, 1, 1 ) ), SWITCH ( TRUE (), ISBLANK ( 'Table'[EndDate] ), DATE ( 9999, 1, 1 ), 'Table'[EndDate] ) )Best Regards,
Specifying 9999 as a placeholder year is a rather bad idea. What will happen is that Power BI will create date hierarchies for all your date fields spanning your minimum data date up to the year 9999. Those are hundreds of thousands of rows for each column that are eating up a lot of space and performance.
If there is no end date, leave it blank and handle it in your logic.
To answer your question - yes it can be done in Power Query but in this particular scenario DAX seems to be a better option.
